'74 gauges
Old Mar 11, 2010 | 01:06 PM
ts_vette_st's Avatar
ts_vette_st
Default '74 gauges
What are the gauges in a '74 C3? Mechanical or electrical? I know the tach is mechanical but not sure about the rest.
Old Mar 11, 2010 | 01:14 PM
1Fordman's Avatar
1Fordman
Speedo and tach mechanical. Clock, amp, temp and fuel electrical.
I think your 74 has an electric oil pressure gauge, not sure if 74 or 75 was when they replaced the mechanical oil pressure gauge with the electrical version.
Old Mar 11, 2010 | 01:26 PM
oldsarge's Avatar
oldsarge
74 has a mechanical oil pressure guage.
Old Mar 11, 2010 | 01:38 PM
Paul L's Avatar
Paul L
Sorry Sarge. It is electric.
Old Mar 11, 2010 | 01:45 PM
ts_vette_st
Where does the mechanical tach drive connect to? When did they change to an electrical tach, 75 76? Was it the same appearance wise as a 74?
Old Mar 11, 2010 | 02:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by tsst
Where does the mechanical tach drive connect to?...
The tach cable fitting on the distributor and from there to the rear of the tach.
...When did they change to an electrical tach, 75 76?...
75 with HEI.
...Was it the same appearance wise as a 74?...
Tachs look the same, but drive differently.
Old Mar 11, 2010 | 02:36 PM
ts_vette_st
75 with HEI.
Thanks Mike! My distributor has been changed so I may need to get a 75 tach.
Old Mar 11, 2010 | 09:01 PM
oldsarge's Avatar
oldsarge
I thought that didn't change until 75 ? :o
Old Mar 11, 2010 | 11:49 PM
7T1vette's Avatar
7T1vette
Oil pressure gauge changed in '74. As a 'minor' point-of-order, the clock is electo-mechanical. It has an electrical winding solenoid with a contact set and a balance wheel with spring/gear mechanical movement. The spring unwinds every 2 minutes when the contacts touch and fire the solenoid, which rewinds the spring. Pre-quartz movement with electric winding system.
Old Mar 12, 2010 | 04:30 PM
aussiejohn's Avatar
aussiejohn
Default gauges...........
old sarge, Paul,
1974 had mechanical tack and electric gauges. Mine HAD a capillary non-Corvette oil gauge fitted, but I bought an electric one from the USA many years ago that was not from a '74, but looks the same font etc. as the other gauges. I thought it was a '72 or '73, but it's electric and it fits.
In 1975, Corvette went to an HEI dissy with no mechanical tach drive, so tach was electric. Several vendors have HEI tach drive distributors, I have one in mine, and you might want to go this way, but the NCRS crowd might frown on it
Regards from Down Under
aussiejohn
Old Mar 12, 2010 | 05:36 PM
Paul L's Avatar
Paul L
Originally Posted by aussiejohn
old sarge, Paul,
aussiejohn
John,
Breakerless SE this summer for me. I like to retain the distributor cover. Can't be done with HEI.
To '74 gauges
