Emergency Brake Light
Old Mar 19, 2010 | 08:42 PM
BurlingtonJohn's Avatar
BurlingtonJohn
Default Emergency Brake Light
Tonight while out for a quick cruise, I stopped for gas. Fired 'er back up and noticed the emergency brake light was on. I can't remember the last time I have ever used the brake, if ever.
Any clues as to a cause and/or solution?
Thanks!
John
Old Mar 19, 2010 | 09:34 PM
my 76 ray's Avatar
my 76 ray
The brake light also comes on if you have an imbalance in the pressures to the front vs rear calipers. You may have a leak in your brake system, air in the brake lines, or problems with your master cylinder. It could also be an electrical short in the brake light wiring. Does your brake pedal feel soft?
Old Mar 19, 2010 | 09:39 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Someone with knowledge of a '78 jump in here. The brake warning light on my '69 comes on when either the limit switch on the emergency brake handle is activated, OR when there is an imbalance between the front and rear brake systems...like one is leaking, low on fluid, etc. That signal comes from the brass valve mounted on the driver side frame rail, next to the steering gear. Check to see if the wire fell off.
Old Mar 19, 2010 | 11:12 PM
BurlingtonJohn
The brakes feel fine ... not a problem. I'm thinking it may be a short, as the car is running as smooth as ever. I have scheduled an oil change with my mech, I'll ask him.
Thanks!
John
Old Mar 20, 2010 | 01:08 AM
7T1vette's Avatar
7T1vette
First, check the level of your brake fluid in both sections of the master cylinder. If they are at different levels, you have a leak somewhere and that is likely the problem. If it is very low, it could have been sucking air and that would cause the problem, too. If there is seal wear on the M/C piston, it could cause a difference in pressure between the two sections. Or, it could be a wiring fault as mentioned above. Best to check it out to make sure there is no major brake problem.
Old Mar 20, 2010 | 07:32 AM
Duke94's Avatar
Duke94
The light will come on when it is grounded so if a wire fell off, nothing would happen. To determine if it is the park brake switch, pull the wire off the proportioning valve (mounted on the frame rail below the M/C). If it stays on, then it's the PB switch, if it goes out then something tripped the brake failure warning switch in the prop valve. Usually a leak or air in the system.
Gary
Old Mar 20, 2010 | 11:02 AM
RippoDippo's Avatar
RippoDippo
Sounds like a full Frame off job!
Check the switch under the centre console hooked up to the Ebrake handle.
Old Apr 11, 2010 | 03:35 PM
BurlingtonJohn
First off, belated thanks for your answers. Checked the master cylinder, there was a diff in fluid levels. Topped off the fluid, problem solved.
As a precaution, had my mech check it out when he was changing the oil. Said everything looked fined.
Time to cruise!
John
To Emergency Brake Light
