Electrical Problem
Old Mar 23, 2010 | 10:11 PM
homscr's Avatar
homscr
Cruising
Default Electrical Problem
When I connect the positive cable to the battery some kind of relay energizes and the ammeter reads a draw of 40 amps, anyone has an idea what it could be. I have isolated the positive cable, the alternator, the voltage regulator, the horn relay, the lights and still have the draw.
Old Mar 23, 2010 | 10:35 PM
The13Bats's Avatar
The13Bats
What relayes are left ...alarm? power antenna...you didnt say what year car?
Old Mar 24, 2010 | 07:29 AM
homscr's Avatar
homscr
Cruising
It is a 1968, and have not checked the antenna relay, don't know that there is an alarm. I'm new to corvettes, just bought this one.
Old Mar 24, 2010 | 09:56 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No power antenna on '68s unless a previous owner added them. If you have the optional alarm system, there will be a key cylinder in the rear panel to arm and disarm the alarm. There is a power window relay for the PW cars.
The assembley instruction manual (AIM) shows the installation of the power windows and alarm.
Old Mar 24, 2010 | 10:41 AM
7T1vette's Avatar
7T1vette
Alarm key [for optional anti-theft system] was on left front fender until '72.
Old Mar 24, 2010 | 11:40 AM
Bo5co's Avatar
Bo5co
40 Amps is a pretty hefty draw, no?
I might yank the fuses one by one to try and narrow the focus.
Do you have a wiring diagram to work with? I can dig up a link for you if not.
Old Mar 24, 2010 | 12:05 PM
Easy Mike's Avatar
Easy Mike
Bassackwards. In the rear panel until it moved to the fender.
Old Mar 24, 2010 | 01:06 PM
southern_vette's Avatar
southern_vette
have someone connect and disconnect the battery cable while you listen and search for the relay that is pulling in. If you can tell us where the relay is it would us help you.
Chris
To Electrical Problem
