YJ8 - How Does One Really Know
Old Mar 30, 2010 | 10:44 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Default YJ8 - How Does One Really Know
My four aluminum wheels from my 1977 Coupe have interesting but not terribly revealing information in them. Each has a casting number "14018395" on the back. Each also has "FW" cast into the back and a number "1" cast back there as well. What I found today when I started to clean them up is a large stamped number "34" and a small but long stamped number "092698201".
Okay you wheel experts, can you point me in the direction of where I can learn more about these wheels. The internet has proven to be less than helpful here so I am turning to the experts, or at least you guys to start.
Hoping someone out there has some good information or sources for some.
Thanks for your help.
David
Old Mar 30, 2010 | 12:51 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sound like they could be original. Go here http://www.corvetteactioncenter.com/...x.php?cmd=area and see if you can obtain a copy of the dealer invoice for your '77. The invoice will list the options the car was equipped with, including the aluminum wheels.
Old Mar 30, 2010 | 01:06 PM
7T1vette's Avatar
7T1vette
Since they are all the same, it is certainly a "set". If they are correct for your year car, odds are overwhelming that they came with the car.
Old Mar 30, 2010 | 01:11 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Thanks Easy Mike. I do have the delivery sheet on this car and it doesn't show the YJ8 option so it wasn't delivered with the Aluminum wheels. I am the third owner so somewhere between delivery and me it picked these up. I have taken them off the car now and removed the old old old tires. I am going to clean them up and put them back into service but in the mean time I have the after market version on them which look very good. I was just checking to see that they are original, and they appear to be, but not certain, hence my post.
David
1977 Orange Corvette Delivery Sheet.pdf
Wheels on the Corvette.
Name:  David 77 Orange.jpg
Old Mar 30, 2010 | 01:12 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I checked all four of them closely and they are all exactly alike and they appear to be a "set". My delivery sheet doesn't show them but I will check the purchase sheet to see if that lists them.
Old Mar 30, 2010 | 01:22 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Default Original Owner Documentation
Well the original purchase sheet does not show YJ8 wheels but I found it interesting that in his documentation I found the attached sheet. Safety Sheet for Aluminum Wheels.pdf.pdf
Can't solve the mystery of when they were applied but will continue to try.
Wish me luck.
David
Old Mar 30, 2010 | 01:46 PM
markids77's Avatar
markids77
Dealer installed option? I worked at a Chrysler dealership some years back and we were forever playing "wheel roullette" for the sales force. I suspect someone liked the white (or red, etc) one yours was parked next to but wanted rallyes... Ta Da!!! instant wheel swap.
Old Mar 30, 2010 | 02:17 PM
GREGG-73's Avatar
GREGG-73
Dave,
If I may suggest...post your query up on the NCRS Tech board. I went through this several years ago, and unfortunately, I did not save this info. Since you are now certain that this was not an ordered option for your car, the issue becomes moot, other than date coding the set. JMO.
Stay in tune....
Old Mar 30, 2010 | 07:26 PM
gbvette62's Avatar
gbvette62
14018395 sounds like a GM part number, but it's not the number the Corvette parts book shows for aluminum wheels. My Corvette parts book shows 14009704 as the 76-79 aluminum wheel, 14002370 for the 79 Pace Car and 14022120 for 80-82s. I have an old set of 76-79 wheels here and can't find a part number on them anywhere. They do have Kelsey Hayes cast between the webbing on the back, and have a 1979 date stamped on them.
The wheels you have are the correct type wheel for a 76-79 Corvette. 76-79 wheels have the natural (unpolished) aluminum finish and the black paint in the flat around the lig nuts. 80-82 wheels are polished with a clear coat and have no black paint on the face of them.
Old Mar 30, 2010 | 07:44 PM
Mike Ward's Avatar
Mike Ward
Those were made by Western Wheel and not by Kelsey Hayes. I've seen them appear before, not sure if they're OEM or not.
Old Mar 30, 2010 | 08:12 PM
GREGG-73's Avatar
GREGG-73
In addition, I just went back through the NCRS archives searching for my part numbers and info. The wheels would clearly read Kelsey Hayes on the back and the part number would be 363768 (1976).
Hope this helps.
Stay in tune....
Old Mar 31, 2010 | 05:22 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
It does help a lot guys, thank you.
I won't be putting this car through NCRS, too many issues, not enough energy to go through that effort, but thank you to all that have given me such good information.
Best regards,
David
Old Mar 31, 2010 | 08:41 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by gbvette62
...My Corvette parts book shows 14009704 as the 76-79 aluminum wheel...
So does mine but that might be the part number for service replacement wheels.
It's my understanding Western makes the aftermarket copies of the Kelsey-Hayes originals.
Old Mar 31, 2010 | 01:00 PM
gbvette62's Avatar
gbvette62
My 76 book shows 363768 for 76 wheels, the 14009704 is the number by 79 book has for 76-79s. I don't have a 77 or 78 parts book.
Old Mar 31, 2010 | 05:45 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
If they're Kelsey-Hayes or Westerns they will say so on the back hub.
I've also run across a repro that simply said 'made in china', no name tho.
I've got a spare set off my 79 and a NOS one in the box, all Kelseys.
Also 2 Westerns hanging on my shop wall.
I'll look at the numbers and see if anything looks familiar.
But let us know if yours have the manufacturers name.
I will add, for what it's worth, the wheels on your orange Vette in your pics do look like Kelseys. The slots in the Westerns are a little different.
Old Apr 1, 2010 | 09:35 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Default I Think The Mystery Continues
Well, decided to keep this going because thus far no one has solved it.
There is no Kelsey-Hayes on the back that I can find.
There is no Wester Wheel on the back that I can find.
There is no Made In China wording on the back that I can find.
So what is there?
Molded "FW" in one location.
Name:  77 Orange Original Wheels Mystery (8).JPG
Molded "15 X 8.00" in another location.
Name:  77 Orange Original Wheels Mystery (9).JPG
Molded "14018395" in another location.
Name:  77 Orange Original Wheels Mystery (7).JPG
Stamped "092698201" on the rim with molded "1" in another location.
Name:  77 Orange Original Wheels Mystery (5).JPG
Stamped "LT" near the stem hole of each wheel. You can clearly see the grooves in the wheels here, just like the originals.
Name:  77 Orange Original Wheels Mystery.JPG
And stamped near the "092698201" number is large numbers stamped "34"
Name:  77 Orange Original Wheels Mystery (6).JPG
So, mystery solving helpers, what the heck is going on here?
I will attach a front picture next, just to show you what these look like up close and personal from the front too.
David
Old Apr 1, 2010 | 09:42 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
And here are a couple of pictures from the front.
Name:  77 Orange Original Wheels Mystery (2).JPG
Name:  77 Orange Original Wheels Mystery (4).JPG
Can't wait to hear what anyone can find.
Thanks for your continued help out there.
David
To YJ8 - How Does One Really Know
Old Apr 1, 2010 | 01:56 PM
KapsSA's Avatar
KapsSA
Definitely not Kelseys. One of the backside pics shows a bit of the webbing, similar to the Westerns.
The slots on Kelseys show some depth, like tunnel vision. Westerns are flared back a bit so you mainly see just the slot, nothing beyond.
I'd bet they're someone's repros. They look to be in very nice condition, maybe a more recent purchase.
Post a pic of the back side of the hub.
I also find it odd that the valve stem holes are in different locations.
Old Apr 1, 2010 | 04:48 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I noticed that as well. There are two in one location, two in another location, and all four are adjacent to the five hole pattern, but at differing location to the openings.
Name:  77 Orange Original Wheels Mystery (3).JPG
Here are pictures of the back of the hubs.
Hey, maybe these are the original Duntov pair from 1973.
Whoever made them they signed them, we just can't seem to decipher the signature, which I believe is what the "FW" represents.
We already figured out they are not Kelsey-Hayes, but who would go to such effort to knock these off and they are very old, been on the car since about 1979 according to the original owners daughter.
And if anyone has a picture of the back of an original Kelsey-Hayes version, and an original Western Wheel version of the YJ8 could you post them, I'd like to see the difference.
Appreciate the help.
David
Old Apr 1, 2010 | 05:45 PM
GREGG-73's Avatar
GREGG-73
David,
Here is the back side of my NEW repro's. I always black out the slots for contrast. So, this shot was in progess. You can clearly make out all the numbers. Good luck to you, trying to prove out a "China Made" part.
I would have thought that in your line of business, you would have known the obvious.
We all get a little smarter everyday....when we try!
Stay in tune...
