A/c freon conversion question
Old Apr 16, 2010 | 07:51 PM
nutsy's Avatar
nutsy
Default A/c freon conversion question
I have the old stuff in my a/c. its a little cool but not cold. garage said anywhere from 250 to 600 bucs to charge it up with old. said he could convert it to the new freon for 149. BUCS out the door. QUESTION 1, will the new freon come out as cold as old one or colder? QUESTION 2, My A/C is original. will this conversion hurt value of car and will it look different? thanks, NUTSY.
Old Apr 16, 2010 | 08:26 PM
zwede's Avatar
zwede
A "quick-n-dirty" conversion (which is all you'll get for $149) will not cool like R12 did. You can make R134a cool as well as R12 but it involves an adjustable POA valve and a parallel flow condenser. If your stuff is in good shape you should probably stay with R12.
If it still cools some it's not empty so it won't need all that much R12. $600 sounds outrageous, BTW...
Old Apr 16, 2010 | 10:02 PM
7T1vette's Avatar
7T1vette
Just call around to some auto A/C repair shops and ask if they have any R12 and if they can just add some refrigerant. If the system is working, you don't have to evacuate it before adding more to get the working pressure right. R12 is hard to find and more expensive than 134a. But the mechanic who made the quote is a rip-off artist. Lose him quick!
Old Apr 16, 2010 | 10:19 PM
mds3013's Avatar
mds3013
You might be able to find R12 around $30-$40lb. It is still around you just have to look for it. I can put my hands on about 100lbs. of it. mds...
Old Apr 17, 2010 | 09:41 AM
nutsy's Avatar
nutsy
thank you all for the info. looks like ill try and find some r12.
Old Apr 19, 2010 | 01:43 PM
smallblock350's Avatar
smallblock350
I have one can of the old R12 for sale if you need it.
$10 plus shipping, I'm in So Cal.
714-296-5025
Mike
Old Apr 19, 2010 | 03:50 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by smallblock350
...I have one can of the old R12 for sale if you need it...
Careful there. I would hate to see anyone get into trouble, but unless your a certified automotive AC technician, it could be illegal for you to sell/ship R12.
Old Apr 19, 2010 | 04:39 PM
Leung's Avatar
Leung
Agree with everyone else. You can also find R12 on ebay.
Old Apr 19, 2010 | 05:48 PM
wnmech's Avatar
wnmech
Check your local craigslist for the R-12. I bought 20 cans for $10 Dollars a can. I see it all the time between $10-25 dollars a can
Old Apr 19, 2010 | 08:08 PM
Tom73's Avatar
Tom73
Most any good auto parts store has R/12, just that you must have a license to buy it.
Old Apr 19, 2010 | 08:13 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
was in the a/c business as a second job years ago. I remember when i bought R-12 for $0.19/can at one point. I would buy 4 or 5 cases at a time and just throw in back the service truck....Just wonder if China,Japan,USSR and others are in line with 134a or, are we the only ones ???
to the op- a good conversion should cost less then $500 -at least in my area.. good luck.
Old Apr 19, 2010 | 09:07 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
switch to duracool.
cheaper
better
faster
Old Apr 19, 2010 | 09:24 PM
Tom73's Avatar
Tom73
Originally Posted by 427V8
switch to duracool.
cheaper
better
faster
May want to check this out at the EPA before even considering using Duracool....
http://www.epa.gov/ozone/snap/refrigerants/hc-12a.html
tom...
Old Apr 19, 2010 | 11:16 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
You might find answers to some of your questions here...
http://www.id-usa.com/how_to_faqs.asp
FWIW, if I decide to re-install an A/C in my C3, it'll almost certainly be on R-134a.
To A/c freon conversion question
