Door Panel install question
Old Apr 20, 2010 | 09:34 AM
ImBatman's Avatar
ImBatman
Default Door Panel install question
Do you put the door handle on first and then install the panel or does the panel go on first and then the handle?
Old Apr 20, 2010 | 09:38 AM
joewill's Avatar
joewill
can't put the handle on after the door panel goes on.. just pull the handle out ( like you are opening the door) and the panel should slip right on thru the door handle hole.
Old Apr 20, 2010 | 10:04 AM
ImBatman's Avatar
ImBatman
Thanks! That is the way I am doing it now but I cant get the upper edge over the metal door tabs at the top of the door. Is there a trick to doing this???
Wade
Old Apr 20, 2010 | 10:12 AM
joewill's Avatar
joewill
mine didn't go over the edge, they just butted up against it, i dunno, maybe your's is different.
Old Apr 20, 2010 | 10:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...can't put the handle on after the door panel goes on...
You can on my '68 and you could on my '74. Trim panel goes on first; door opening handle after that.
Old Apr 20, 2010 | 04:14 PM
Alan 71's Avatar
Alan 71
Hi,
At least on 70-72 cars you can put the door panel on first, get it in position, and then use a small screw driver to pry the lever of the mechanism out far enough to slide the lever on.
Regards,
Alan
I have the top of the door panel over the metal tabs. I didn't like the way you could see down into the door mechanisms past the window with the door panel not over the tabs. It does take a bit of work to get it done.
Old Apr 20, 2010 | 08:28 PM
vettes4evr's Avatar
vettes4evr
Alan, I KNOW you have a great picture of this! You've got better photos of every part of a C3 Corvette than GM has.
To Door Panel install question
