Idler Arm Replacement
Old Apr 26, 2010 | 12:58 PM
crzynate25's Avatar
crzynate25
Default Idler Arm Replacement
First off let me thank everyone for all there help so far! Everyone has been super helpfull with helping me get my recent purchase up and running!
But to my real question, what i thought would be a simple change out turned into an evening of pulling my hair out.
With replacing my idler arm, for inspection, I can't seem to remove the bolt from the idler arm off of the relay arm. I heard slight persuasion with a hammer could knock it loose but that isn't happening. Is there something I am missing trying to get this bugger off?
Thanks again!
Old Apr 26, 2010 | 01:13 PM
7T1vette's Avatar
7T1vette
Your best approach would be to get/use a gear puller. Take the nut off the stud, turn it upside down then put it back on the stud so that the top surface of the nut is at the same level at the top of the stud. Use that "flat" as the place to locate the threaded member in the puller and put the jaws behind the bulge in the rod. Then crank it off.
You could also use a "pickle fork"; but you needed to do that before you took the idler arm off the frame so there would be something solid to hold the links in place.
Old Apr 26, 2010 | 02:26 PM
crzynate25's Avatar
crzynate25
Thanks 7t1 - I actually put it back on the frame and have a pickle fork that I wrenched on it a little bit. But not a budge. I am going to try and use the gear puller and hopfully I can get it to pop.
Old Apr 26, 2010 | 02:41 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Crzynate25 - There are several different sizes of pickle forks and pullers. I have used a tie rod puller and the smaller pickle forks successfully. If you cannot get it off with what you have - 2 suggestions - generally places like Pep Boys & Auto Zone will loan out tools. If that doesn't work for you, I will bring mine to the Allentown Area Corvette Clubs Show Sunday at DeSales University. You can borrow mine.
I am about 30 minutes south of you in Montgomeryville. If you can get here - you can get them before.
John
Old Apr 26, 2010 | 08:09 PM
7T1vette's Avatar
7T1vette
If you get a puller on it and crank it as far as you can, and it still won't break loose....give the 'ram' screw a good whack with a steel hammer. The shock load from that will almost always cause the joint to split.
Old Apr 27, 2010 | 01:16 PM
crzynate25's Avatar
crzynate25
Thanks guys - Hopefully i can get out to work on it tomorrow when its gonna be a little nicer here. And we'll see what I can come up with. But either way, John, I am in lansdale every sunday. Maybe, I'll have to swing by and say hi.
Old Apr 29, 2010 | 07:13 PM
Go Vette Go
Sounds good. Let me know if you still have a problem - I will be in Allentown this Sunday & can bring some tools!
Old Apr 30, 2010 | 12:52 PM
crzynate25's Avatar
crzynate25
So last night after an hour of so of yelling and cursing the idler arm, I finally got it off and the new one on!!! Now, finally, the vette is up to inspection and can drive it around without 06/06 inspection stickers! Thanks for the tools offer John - but it doesn't look like I'll need them.... for now. I am hoping to make it to Allentown on Sunday but will be on my way back from AC and a bacholer party for my brother so we'll see.
Old Apr 30, 2010 | 01:02 PM
GD70's Avatar
GD70
That means you WON'T make it!
Old Apr 30, 2010 | 01:47 PM
Go Vette Go
Guess I will have wait for a later date to meet you!
To Idler Arm Replacement
