Tank sticker
Old Apr 29, 2010 | 11:23 PM
sentinal77's Avatar
sentinal77
Default Tank sticker
So I have the rear bumper cover off and the spare tire tub removed and I can see paper beginning to curl up and I'm fairly sure it's my tank sticker
I should have the tank dropped in a day or two (pictures will come) and I know what an important document that is, so what's the best way to get the actual sticker off of the tank? I've heard steam it off or just carefully peel it.. What do yall think and what's worked in the past?
Thanks in advance.
Old Apr 29, 2010 | 11:48 PM
Father N Son's Avatar
Father N Son
do it the way a fellow texan did, close your eyes and rip it off.
Old Apr 29, 2010 | 11:59 PM
I'm gone's Avatar
I'm gone
Wow, that would be great to see! I've owned my '77 for 22 years now and have wondered if mines still there, would be great to see pics. Good luck!
Old Apr 30, 2010 | 06:52 AM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
I used a razor blade and scraped it off. The glue was brittle and came off easily.
Old Apr 30, 2010 | 09:40 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Father N Son
...close your eyes and rip it off...
I hope that is an attempt at humor. The last thing any one should do is rip it off.
SENTINAL77: Contact these folks http://www.corvetteactioncenter.com/...x.php?cmd=area and see if you can get a copy of the dealer invoice for your '77. The invoice will had everything the build sheet has, plus prices, original delear info, date shipped, etc.
Old Apr 30, 2010 | 10:45 AM
bruiser's Avatar
bruiser
St. Jude Donor '15
On a 77 the build sheet is not on the tank. It is on top
of the shield above the tank.
Old Apr 30, 2010 | 11:23 AM
Mike Ward's Avatar
Mike Ward
Aside from nostalgia, the tank stickers on later C3s have little value- the VIN already indicates which engine the car came with, and the cars had been watered down with virtually no rare/desirable options left to choose from.
I'd take a picture of it and leave it alone.
Old Apr 30, 2010 | 02:30 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
nostalgia goes a really long way!!!
Old Apr 30, 2010 | 02:49 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Yep, I prize each one of my tank sheets.
I agree with the razer blade, work it underneath as you lift the sheet up. It'll just continue to deteriorate if you leave it up there.
And don't try to clean it or brush it off. The ink will smear right off.
I photocopied each of mine and glued the copy back on with a note on it.
Then simply put the originals, dust and all, in one of those plastic binder sleeves.
Except the Pace Car, that got the original back on.
Old Apr 30, 2010 | 10:30 PM
mds3013's Avatar
mds3013
Got mine last week. The best thing I found was where my car was delivered to. I already knew what options it had. mds...
Old Apr 30, 2010 | 11:02 PM
Sebago Shark's Avatar
Sebago Shark
St. Jude Donor '09
Dropped one of my tanks a few weeks ago also. Found a nice little surprise.
To Tank sticker
