Extending Timing Light Cord
Old May 1, 2010 | 01:31 PM
loquinho's Avatar
loquinho
Default Extending Timing Light Cord
So... the corvette battery is in the back... and the timing light has a cord that's about 4' too short. I don't know why this problem didn't occur to me before I tried to hook it up.
I don't have a spare battery around, but what I do have is a good length of Romex house wiring and a set of jumper cables. Would either of these work to get the power from the battery to the jumper cables?
Old May 1, 2010 | 01:36 PM
Aggitated Monkey's Avatar
Aggitated Monkey
I just connect the possitive to the hot wire at the alt and the neg to any ground. Has always worked for me.
Old May 1, 2010 | 03:32 PM
7T1vette's Avatar
7T1vette
Power supply wire to the output lug on back of the alternator; ground wire to the ground lug on the back of the alternator (has the black wire attached to it).
Old May 1, 2010 | 04:18 PM
garage-ghost's Avatar
garage-ghost
Old May 1, 2010 | 04:40 PM
thegazman's Avatar
thegazman
Default thegazman
Works for me.
Old May 1, 2010 | 06:03 PM
PRNDL's Avatar
PRNDL
Well, in the past I used jumper cables to get to the battery...
until reading on this forum about the other options available.
Old May 1, 2010 | 07:54 PM
vettes4evr's Avatar
vettes4evr
...and all those years I was using extension leads and trying to keep them separated! DUH.
Old May 2, 2010 | 09:53 AM
oldsarge's Avatar
oldsarge
Good idea, nice to know, makes things, a whole lot simpler, doesn't it.
Old May 2, 2010 | 10:23 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
This is one of those topics that comes up pretty often. I snapped a pic of the way I connected my timing light when I had a stock style small block.
Keep in mind when you are doing this, I have reclocked my alternator to change the locations of the connections on the rear of the alternator but the idea is the same. Red lead on the positive and the black lead to any ground.
To Extending Timing Light Cord
