trim tag paint code question
Old May 3, 2010 | 12:09 PM
oldsarge's Avatar
oldsarge
Default trim tag paint code question
The trim tag on a 74 shows paint code 22L, it is a med blue vette, why is it not 922 as per the book?
Old May 3, 2010 | 12:31 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Not sure whether it applies to 74s, but some of the later tags drop the 9.
NCRS Judging Guide will probably have a blurb on it.
Old May 3, 2010 | 12:37 PM
GREGG-73's Avatar
GREGG-73
Sarge,
I believe in the later year 74's, the first 9 was dropped off by GM....So you should be OKAY. Nothing to fret about. I am sure someone here will offer a more exacting explaination.
Stay in tune....
Old May 3, 2010 | 01:28 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Black Book?
My old 87 copy shows 922.
My newer 01 copy shows 22 with a notation.....
"Exterior color code on trim plates was generally a two number code followed by the letter L. The code may also appear with a 9 before the two numbers and no letter following."
edit...73 shows the 9 used, 75 doesn't. 74 transittion year?
Old May 3, 2010 | 01:35 PM
Mike Ward's Avatar
Mike Ward
The books have been wrong for decades. Not sure why it's never been fixed.
Old May 3, 2010 | 01:37 PM
oldsarge's Avatar
oldsarge
Originally Posted by KapsSA
Black Book?
Did the "L" stand for anything, are there other letters involved, with any meaning? My freind just inherited it and I am trying to sort out any other info, I can get him.
Old May 3, 2010 | 01:44 PM
KapsSA's Avatar
KapsSA
Don't know.
I know my 78SA shows "U" for the upper color and "M"(middle?) for the lower color.
Old May 3, 2010 | 02:55 PM
Mike Ward's Avatar
Mike Ward
GM paint code convention used U for upper and L for lower when it came to two tone paint jobs. Single coloured cars used the L nonetheless.
Popular myth is that L stands for lacquer and U for urethane.
Old May 3, 2010 | 03:48 PM
oldsarge's Avatar
oldsarge
Mike;
Thanks, It is funny, because when I was looking at that "L", I thought that too, but it has nothing to do with laquer, correct? I also noted that the newer Black Books have changed the paint code numbers to 2 digits, and state that it is followed with the "L", but don't say why.
Old May 3, 2010 | 03:50 PM
GREGG-73's Avatar
GREGG-73
Sarge,
Use the "Search" function here...., as this topic has been discussed numerous times.
Stay in tune...
Old May 3, 2010 | 04:51 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...more in depth reading here.
http://forums.corvetteforum.com/c3s-...rig-miles.html
Old May 3, 2010 | 08:33 PM
KapsSA's Avatar
KapsSA
OK.....
why do BOTH my two-tone 78s use 'M' for the lower? Both the Pace and SA.
And 78 was really the first true two-tone C3.
On my Pace Car build sheet it shows...
19L black lwr
19U black upr
47M silver middle
78SA sheet is same theme.
Old May 3, 2010 | 09:40 PM
Paul Borowski
OK.....
19L black lwr
19U black upr
47M silver middle
....if I'm remembering correctly, I think the '78 Pace Cars started out as an all Black car, with the Silver added over the "all Black car".
...I think that has something to do with the way they were coded. 19L, 19U.
Old May 4, 2010 | 01:08 AM
KapsSA's Avatar
KapsSA
Yep.
I believe it wasn't till Bowling Green production that they truely went with a half and half base coat under the clear.
But aren't they coded differently?
To trim tag paint code question
