Interior dye ?
Old May 4, 2010 | 09:02 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Interior dye ?
I need to dye a couple of new interior pieces. Kick panels and windshield pillar cover .....etc....
Which product do you recommend for a good spray can match for 74 med saddle?
Thanks.......
Old May 4, 2010 | 09:33 AM
sweeet76's Avatar
sweeet76
Willcox Corvette will have the exact color match. Just tell them the year and color and its done.
Old May 4, 2010 | 09:37 AM
TopGunn's Avatar
TopGunn
Yes, I agree. I used theirs on my Med Saddle, comes out perfect. Get the prep and the clear coat also.
Old May 4, 2010 | 12:10 PM
7T1vette's Avatar
7T1vette
SEM "Color Coat" interior dye (elastomeric coloring agent) is what you should use. If Willcox spray stuff is really "dye", it will be OK; if it is really 'paint', you will be using the wrong material on them. Also, interior pieces do not get "clear coat". They are plastic parts and dye should be used to recolor them.
Old May 4, 2010 | 12:40 PM
TopGunn's Avatar
TopGunn
I very well could be mistaken but I thought I remember a clear protective coat being applied over the dye. The clear was made by the same manufacturer. I'll look when I get home it's been awhile since I did mine.
Old May 4, 2010 | 12:46 PM
noonie's Avatar
noonie
The SEM formula for medium saddle is #4850. Available at most auto paint jobbers.
Here are the instructions for it's use and the accessory products suggested.
http://semproducts.com/images/Users/...RAP-1_1009.pdf
If at all possible get a cheap touchup gun at harbor freight, it doesn't take much air, and get the paint in pint or quart form. Will last forever and will always match. I used some the other day that was 30 years old.
Old May 4, 2010 | 04:18 PM
7T1vette's Avatar
7T1vette
Actually, for $5 you can purchase a Pre-Val bottle/gas cannister sprayer [at the same store you get the SEM dye]. It is easy to use and will do a fantastic job of spraying the interior dye on your panels. Don't waste more money on spray equipment just for this job. The end result will look like 'factory' quality.
Note: Per prior post: I'm not saying that Willcox doesn't sell [or recommend] a clear coat for interior panels. I'm just saying that they were never made with a clear coat, and they shouldn't be, IMO. A 'clear coat' leads me to believe that their "dye" may actually be a 'paint' which you DO NOT want to use on plastic panels.
Old May 4, 2010 | 05:45 PM
dennis's Avatar
dennis
Thanks.......
Since I doubt you can get what was originally used to color the interior pieces by GM, REM appears to be the "go to" elastomeric replacement
I used RM's version some 30+ years ago to do my 70 in 74 silver. Still have the old siver colored seat covers, held up great. Its all in the prep.
You'll also find that dupont mixed with different sheen levels, so as stated.... no clear.
Just wish people would stop calling it dye
Old May 4, 2010 | 09:36 PM
TopGunn's Avatar
TopGunn
The clear coat has nothing to do with durability, it's used to provide a glossy or satin finish appearance. I have it on mine. See pg 6 of the document Noonie posted.
Old May 5, 2010 | 12:26 AM
7T1vette's Avatar
7T1vette
If the clear coat is "dye", no problem. Beauty is in the eye of the beholder.
Old May 5, 2010 | 01:57 AM
KSM's Avatar
KSM
Their are some good articles out hear on this subject.......my best advice is clean/strip the parts well. Every bit of the old dirt and interior shine product like Armor has to be removed.
The better the prep the better the finished product will be. Second the dye is vary sensitive to humidity.......I had to dye my interior in the basement of my house to control the humidity with the A/C.
Hear is a pict of my 71 all parts are dyed/restored except the dash pad and door panels/ans seat covers they are new. Hear is a part that I cleaned with a product I use on my boat Nauticalease is strips everything off....dirt, wax, smoke ect. I did not have to dye a few of these parts after the cleaning. You can see the oil and wax floteing brfore the wipe down it took only a few seconds for it to strip it down. clean.
To Interior dye ?
