gravity bleed
Old May 5, 2010 | 03:26 PM
jude's Avatar
jude
Default gravity bleed
Anybody tried a gravity bleed on brakes? I heard if you have the time it's the way to go. Thanks for any help.
Old May 5, 2010 | 03:38 PM
AOS_L79's Avatar
AOS_L79
I use that method exclusively, though I've heard good things about Motive Products power bleeders. Sometimes with gravity bleeding I've run into times where no fluid will come out of the lines-even stepping on the brakes with open bleeders. I've no idea why that happens, but eventually fluid will come out. I haven't gotten 'rock hard' brakes from gravity bleeding either, so we'll see what others have to say.
Last edited by AOS_L79; May 5, 2010 at 03:41 PM. Reason: don't believe links to non supporting vendors are allowed
Old May 5, 2010 | 04:06 PM
GPGG70's Avatar
GPGG70
Hey Jude,
Pardon the pun.
I gravity bleed my brakes on my 70 vert last fall. I didnt know the history of the fluid as to how long it had been in the system plus wanted to try the gravity bleed method. It was a overall success. I read here to jack the rear end of the car 16 inches to the wheel bearing hub from the floor to help remove any air in the system. I then bleed all the calipers. I had a plastic bottle with a lid and drilled a hole in the lid then found a hose that would fit tight over the bleeder nipple & ran inside the bottle. This bottle is somewhat clear so I could see the flow (driping) and air bubbles flowing into the bottle. I over killed the amount of fluid I flushed thru but I now know whats in the system. My brake peddel was and remains hard to this day.
The way I did it also resulted in very little mess with the fluid.
I'm really pleased. I have a brand new motive bleeder still in the box in my cabinet. I just wanted to try the gravity bleed method first.
Hope this helps.
Old May 5, 2010 | 07:47 PM
72ls5fla's Avatar
72ls5fla
It is the only way I bleed brakes on a Vette.
The fronts are easy - the rears have to be done PASS inner/ PASS outer then DVR inner /DVR outer.
Always get a rock hard brake pedal.
Old May 5, 2010 | 08:09 PM
guappy's Avatar
guappy
I've also used this method an sometimes it the only way to get a good pedal.
Old May 5, 2010 | 09:21 PM
thatcorvetteguy's Avatar
thatcorvetteguy
If you have the time, it's the only way to go.
Old May 5, 2010 | 10:39 PM
Jeff_Keryk's Avatar
Jeff_Keryk
I've tried every which way. I'm pretty jealous of those who have had success other ways, but the only thing that worked for me was the Motive Bleeder. And I use low pressure like 10-12 psi. Give it a shot and best of luck to you!
Old May 6, 2010 | 10:21 PM
dburgjohn's Avatar
dburgjohn
I tried gravity, pump the pedal and vacume with no luck. Bought the motive and love it.
Old May 6, 2010 | 10:44 PM
alswagg's Avatar
alswagg
I replace the bleeder valves with speedy bleeders. One person operation. Takes about 20 minutes to bleed all 4 wheels. Extremely easy. Who has the time to screw with bleeding brakes for days at a time. I would rather be driving. To each his own. Al
Old May 6, 2010 | 11:47 PM
Berserker78's Avatar
Berserker78
Can someone explain this gravity bleeding? I blew a line on my 78 this weekend, so I am going to replace them all with stainless, but I hate bleeding brakes.
If there is an easier way, I would love to hear it.
Old May 7, 2010 | 12:49 AM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
I would also be interested in a how-to for gravity bleeding.
Old May 7, 2010 | 01:00 AM
Berserker78
I just realized that there is a sticy over in C3 tech with that info (and a lot more).
Old May 7, 2010 | 10:33 AM
tomgallucci57's Avatar
tomgallucci57
so by lifting the rear 16 inches,and the front tires being on the car,which bleeder did you start with,etc. im about to do mine any minute. thanks,tom
Old May 7, 2010 | 10:37 AM
tomgallucci57
plus,where exactly did you measure from to get the 16 inches
Old May 7, 2010 | 10:51 AM
GPGG70's Avatar
GPGG70
Thats a good question. I cant remember now. I think I started with the passenger inner rear then the outer then switched to the driver side. I can say I more then likely didnt bleed my brakes the correct way (order)but there is a sticky at the top of the tech section here in the C-3 section with a lot of info in it and after you read it then you can decide what route to take.
Like I said, From reading the info on this forum I raised the back end up and placed jacks under the car for safety with the front tires on the ground and bleed the brakes. I'm still pleased with the results of gravity bleeding the system and the way the pedel feels. Make sure you keep the M/C full.
Hope this helps.
Old May 7, 2010 | 06:58 PM
alswagg's Avatar
alswagg
http://speedbleeder.zoovy.com/ Check out these speed bleeders. Cheap around $7 ea Make brake bleeding much easier, one person job. No need for jacking up car, to precarious angles. Al
Old May 8, 2010 | 10:55 AM
tomgallucci57
i blead my new calipers yesterday,started at inner pass. then outer, then driv. inner,then outer,fluid came out prettly easily,but did have to push in on bleeder nut to get suction,it only took a few minutes at each bleeder,the front ones were taking forever for fluid to flow,so i put on the vaccuum bleeder from harbor freight,pumped it to 15 lbs. and it drew the fluid right out,i then gravity blead them,like the rears. never touched the brake pedal once.ive got good pedal,and everything seems good, only went around the block twice,so i will be doing the 50 mph hit the brake trick soon,and probably do it 4 or 5 times. it is a manual brake system,but i feel it should have more grabbing power at the front,and it does have new rubber hoses all around.i remember when i was 16 years old,a friend had a 65 impala with drums up front,and it stopped seemingly better than my 68 with discs. oh well, talk to you latter and always the best to you. tom
To gravity bleed
Old Oct 24, 2010 | 10:35 AM
Jon S's Avatar
Jon S
Curious - why do you bleed the inner before the outer? I thought you bled the outer most bleeder first? I followed the sequence rear pass, dr pass, pass front, driver front. Maybe that's my problem. I just can't get a firm pedal and it goes down too far despite changing out the master and all 4 wheel cylinders.
Old Oct 24, 2010 | 11:28 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Old Oct 24, 2010 | 01:38 PM
MrJlr's Avatar
MrJlr
Motive....motive motive motive !
Flushes the system.....perfect pedal everytime.
Sorry - I've tried gravity....all it does is keep me down (pun).
