Front clip queston
Old May 10, 2010 | 11:25 AM
BEJ's Avatar
BEJ
Default Front clip queston
Can anyone explain this odd spacing where the front clip meets the door? The gap is identical on each side. Is this just an example of poor assembly or could there be something more serious going on? Any help would be greatly appreciated.
Thanks,
Bryan
Old May 10, 2010 | 01:09 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by BEJ
...Is this just an example of poor assembly...
Not necessarily poor assembly; just an old car. The door needs to be raised. I'm betting the rear edge is also low.
Old May 10, 2010 | 04:24 PM
Alan 71's Avatar
Alan 71
Hi Bryan,
I agree.
From the picture the door looks low. You can see the 'feature line' at the middle of the door doesn't match the line in the front fender. They matched originally and still should be able to.
I think... hinge issue.
Regards,
Alan
Old May 10, 2010 | 05:05 PM
longbros's Avatar
longbros
If I had to guess, I would say the door is low, and may have been off the car and/or repaired. The other possibility is that the front clip was replaced and/or repaired and not positioned correctly when it was bonded on.
Old May 10, 2010 | 05:23 PM
BEJ's Avatar
BEJ
Thanks for the responses. I'm thinking the front clip may
have been off because both sides look identicle. Hard to
imagine Botha doors belong equally low.
Old May 10, 2010 | 05:36 PM
GD70's Avatar
GD70
Originally Posted by Alan 71
Hi Bryan,
I agree.
Regards,
Alan
Open the doors, and lift at the rear to see if there's any up & down movement. The hinge bushings could be shot as well as the hinges being out of alignment.
Glenn
Old May 10, 2010 | 07:06 PM
BEJ's Avatar
BEJ
Glenn
Tried that and absolutely no play.
Old May 10, 2010 | 08:36 PM
longbros's Avatar
longbros
I think the tip off here is that the bottom of the front fender does not line up with the rocker panel. If the front clip or front fenders were removed and replaced, part of the critical alignment is along the bottom of the front fender, using the mounted rocker panel as a guide. It appears that the fender is too high.
To Front clip queston
