Where is the best place to buy bolts and nuts? I am rebuilding the rear suspension in my 1979 and I do not want to put back in the car the same old bolts and nuts. I have gone through some threads and I found that some people buys the bolts and nuts from hardware stores, Is this an option or is it better to get them at a corvette parts store?
What is the best grade to get? if You think the hardware store is an option and finally can You recomend a hardware store?
Thanks for any advise
Fastenal is going to be local to you. Just Google them and see where they are located. McMaster Carr is another option. I would not use hardware store bolts on suspension parts. They should be Grade 8 bolts, most hardware stores do not carry Grade 8s.
If you want prepackaged correct in style and markings, for your car - I would recommend Paragon Reproductions.
I used them for all my replacement bolt/nut/washer/fasteners for my restoration and was VERY pleased. However - you pay a premium to have them all neatly labled and packaged up.
I just replaced Trailing arms, bushings, shocks, calibers, etc.. On the back of my 1982.
I am so happy that I found out about Van Steel on this forum. Dan was extremely helpful and patient when dealing with my questions and tech questions. The point is I bought everything from him including bolts , nuts, clips etc.. He told me what I needed and supplied them quickly and at a good price. It was very helpful for the rookie ( me ).
Search the forum for Van Steel
P.S. I plan on creating a new post soon to voice my positive dealings with Dan at Van Steel
My local farm supply and local chain Hardware have grade 8 stuff,,,I replace everything I take off with new grade 8 items. The Hardware store even carries show chrome nuts/bolts as well.
Grade 8 bolts are generally the best. Strong and surface hardened. The hardening make them more corrosion resistant.
Some bolts in the suspension are Grade 5. If GM put a Grade 5 bolt in your suspension you should think about keeping Grade 5. Grade 5 bolts have a little more flex. It may be that Grade 5 was selected because of this characteristic.
Also, some bolts ARE NOT REPLACEABLE with hardware store bolts. For instance the bolts that connect the lower front control arms to the frame. They have non-threaded shanks to closely match the holes in the frame mounting brackets. These bolts actually act as pins. Also the trailing arm bolts act as pins. The threaded surfaces are just to mount a nut to keep them from falling out. The repro trailing arm bolts have an extensively threaded shank that will cut into the frame. The stock bolts are untheaded where they pass through the frame and will not cut into the frame.
Don't use hardware stainless steel bolts in the suspension. Hardware stainless steel bolts are really not that strong. If you want stainless steel bolts, you need to get aircraft quality stainless bolts. They are stronger than grade 8 but $$$$$$$.
ACE Hardware stores have most of the Grade 8 bolts I need. For a better selection I go to Fairlady Hardware in old town Torrance. They have a much larger selection of Grade 8 bolts and also stainless and other hard to find bolts. I'd guess there are a few other stores with large selections. Fairlady also gave me a recommendation of a store in Orange County, but I forget the name.
Lowes carries a nice selection of grade 8
also-as he says most generic stainless bolts are quite weak, less than grade 5 in many cases. Stay away from cheap stainless bolts in anything that has a load on it.
I typically get all my Grade 8 bolts from Lowes, Ace or Home Depot. For my suspension, I could not find exactly what I needed, so I went to a local bolt supplier and got a sack full for $5. I think the guy just put the $5 bucks in his pocket. I guess they are not set up to supply small fish like me. Sometimes you just get lucky.
Mcmaster Carr has a good selection of black coated nuts and bolts but you will have to buy them by the box. Be mindful of the length of bolt you take out because back in the day, GM used odd length bolts 5/8" 7/8" etc. The hardware store bolts will only be in 1/4" increments at best.
Very good info.. Do You think I am better off buying a kit from a Corvette store? so that I dont get the wrong thing in the wrong place.
Or is it OK to put back the same old bolts?
I thought it would be better to buy stainless but apparently not..
Thanks for the info
Thanks for the advise I was ignorant about this and only thought of the benefit of rust resistance.. It seems the best thing for me is to go and get the right bolts from my Corvette parts provider. What do You think? It seems a hustle to have to get sizes and threads and grades for this bolts... I am going the lazy way about this I think
Gary
This would match the rest of the car nice.. I have a black theme going, I painted every part that came out of the car, black. I just dont like the I dea of having to buy the whole box of each size... Thanks for the advise
Fastenal seem like a good idea to me when I checked them out, because it says on the homepage that they carry kits for specific cars, But I don't know if it is my computer or their website that is too slow and I went to sleep before I got a list of the cars they carry the kits for.. Thank You very much for the info
If you want them to stay looking good, you need to buy cadmium plated (silver) bolts or phosphate coated (black) bolts for your project. As noted above, I don't know that you can find Grade 8 bolts in stainless, unless they are aircraft quality.
