Build sheet help
Old May 22, 2010 | 09:21 AM
ahough76's Avatar
ahough76
Default Build sheet help
I have a 69 corvette in which my father purchased brand new. This morning I was able to reach through the gas fill area and grab the build sheet on top of the gas tank. It came right off and is in decent shape. I had to to brush off lots of dirt and dust. Is there anyone I can send this sheet to have cleaned, restored and decode this sheet? Any help is appreciated.
Old May 22, 2010 | 10:17 AM
GREGG-73's Avatar
GREGG-73
Slap it between two pieces of thin plastic....keep it original & dry in a safe place....you can decode the car yourself.....
Congrat's on the find....
Wheelbase: 98" Track: 58.7" Front / 59.4" Rear Height: 47.8" Coupe
Length: 182.5" Width: 69" Curb Weight: 3,245 lbs.
Tire Size: F70x15" Plant: St. Louis
The base engine for the 1969 Corvette was changed to 350ci 300hp. Famed designer Harley Earl died at age 75. John DeLorean became the general manager of Chevrolet and canceled work on the XP-882, a four-wheel drive mid-engine test Corvette.
1969 Options:
Code
Description
Quantity
19437
Base Corvette Sport Coupe
22,129
19467
Base Corvette Convertible
16,633
Genuine Leather Seats
3,729
A01
Soft Ray Tinted Glass, All Windows
31,270
A31
Power Windows
9,816
A85
Custom Shoulder Belts
600
C07
Auxiliary Hardtop (Convertible)
7,878
C08
Vinyl Covering For Aux. Hardtop
3,266
C50
Rear Window Defroster
2,485
C60
Air Conditioning
11,859
F41
Special Front and Rear Suspension
1,661
G81
Positraction Rear Axle
36,965
J50
Power Brakes
16,876
J56
Special Heavy Duty Brakes
115
K66
Transistor Ignition System
5,702
L36
427ci 390hp Engine
10,531
L46
350ci 350hp Engine
12,846
L68
427ci 400hp Engine
2,072
L71
427ci 435hp Engine
2,722
L88
427ci 430hp Engine
116
L89
Aluminum Cylinder Heads For L71
390
MA6
Heavy Duty Clutch
102
M20
4 Speed Manual Transmission
16,507
M21
4 Speed Manual Close Ratio
13,741
M22
4 Speed Manual Close Ratio Heavy Duty
101
M40
Turbo Hydra-Matic Automatic Transmission
8,161
N14
Side Mount Exhaust System
4,355
N37
Tilt-Telescopic Steering Column
10,325
N40
Power Steering
22,866
PO2
Deluxe Wheel Cover
8,073
PT6
Red Stripe Tires F70x15
5,210
PT7
White Stripe Tires F70x15
21,379
PU9
White Letter Tires F70x15
2,398
TJ2
Front Fender Louver Trim
11,962
UA6
Alarm System
12,436
U15
Speed Warning Indicator
3,561
U69
AM/FM Radio
33,871
U79
AM/FM Radio Stereo
4,114
ZL1
Special L88 Aluminum Block
2
Serial Numbers: 194379S700001 through 194379S738762
For Convertibles, the fourth digit is a "6"
Suffix:
GC: 350ci, 300hp MT, IG LT: 427ci, 435hp MT, HC
GD: 350ci, 300hp MT, AC, IG LU: 427ci, 395hp MT, AH, HC
HW: 350ci, 300hp MT LV: 427ci, 430hp (L-88) AT
HX: 350ci, 350hp MT, AC LW: 427ci, 435hp AT, AH
HY: 350ci, 300hp MT LX: 427ci, 435hp AT
HZ: 350ci, 300hp AT ME: 427ci, 430hp (ZL1) MT
LL: 427ci, 390hp AT MG: 427ci, 430hp (ZL1) AT
LM: 427ci, 390hp MT MH: 427ci, 390hp MT, IG
LN: 427ci, 400hp AT MI: 427ci, 390hp AT, IG
LO: 427ci, 430hp MT MJ: 427ci, 400hp AT, IG
LP: 427ci, 435hp MT, AH MK: 427ci, 400hp MT, IG
LQ: 427ci, 400hp MT MR: 427ci, 430hp (L88) MT
LR: 427ci, 435hp MT MS: 427ci, UU
MT=Manual Trans, AT=Automatic Trans, PS=Power Steering, AC=Air Conditioning, AH=Aluminum Head, IG=Transistor Ignition, HC=Heavy Duty Clutch, UU=Uncertain Usage
Base Engine: 350ci V8 300hp
Stay in tune....
Old May 22, 2010 | 10:18 AM
JW3101's Avatar
JW3101
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
Most of the codes you can check online - can you post a photo or is it unclear? I can check my book as well for you.
Here are copies of mine ((you should be able to see some of the codes/descriptions)
Old May 22, 2010 | 10:19 AM
JW3101's Avatar
JW3101
Gregg-73 beat me to it.
Old May 22, 2010 | 10:53 AM
7T1vette's Avatar
7T1vette
Place it in an "archival" quality, non-acidic plastic jacket. Some even have UV protection so the sun's rays don't cause the ink to fade. If you want to be certain of how to care for it/clean it, etc., call a document restoration service.
DO NOT use Scotch tape to 'stitch' pieces back together.
Old May 22, 2010 | 12:05 PM
JW3101's Avatar
JW3101
I recieved my two tank stickers when I bought the car - one is loose and in three sections and the other is sealed in some type of plastic - but they used Scotch tape on it prior to sealing it up.
Old May 22, 2010 | 10:28 PM
Mark G's Avatar
Mark G
Isn't there someone on Ebay that can make you an exact (new) duplicate? If not, check with the Camaro crowd. They might know too...
Mark G
Old May 23, 2010 | 02:46 AM
thegavel's Avatar
thegavel
Mark G
Here ya go.
http://corvetteexhibition.com/cgi-bin/stickerHome.pl
Gav
Old May 23, 2010 | 05:03 AM
Yankeededandy's Avatar
Yankeededandy
What I would do first is a high res scan and save it digitally. It is much easier to make a digital copy more legible.
Old May 23, 2010 | 08:53 AM
Clams Canino's Avatar
Clams Canino
Originally Posted by thegavel
Whatever that site makes.. it's nothing like a build sheet or a window sticker. ie Crap.
-W
To Build sheet help
