Stripped screws...
Old Jun 12, 2010 | 10:22 PM
The13Bats's Avatar
The13Bats
Default Stripped screws...
I would assume you purists run into stuff like his and have to figure out ways to fix it and keep things all stock,
hopefully the answer isn't buy a whole new dash,
In my case the car is a 69 the screws that go from the inside edge of the center gauges to the side dash pads are stripped and the gauge bezel is loose...fix ideas please!!!
Many thanks!
Old Jun 12, 2010 | 10:37 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
dry wall anchors
Old Jun 12, 2010 | 10:39 PM
The13Bats's Avatar
The13Bats
dry wall anchors
Really?!?!?!
You mean the little plastic ones?....hum....might just do it....
Old Jun 12, 2010 | 10:45 PM
...Roger...'s Avatar
...Roger...
Fill the holes with fibered epoxy and redrill the holes.
Old Jun 12, 2010 | 11:45 PM
noonie's Avatar
noonie
Toothpicks alone or with epoxy are easy.
Old Jun 13, 2010 | 12:25 PM
7T1vette's Avatar
7T1vette
Use some JB Weld putty-epoxy [stick form] to fill the existing hole, then redrill to the correct size and install the screw. You may want to enlarge the hole before you install the epoxy, so that you can have epoxy on the front and back side of the new hole. The epoxy 'patch' doesn't have to be very thick to support that little retaining screw. If you have some matching vinyl dye for your interior color, you can use a little artist's brush to recolor the patched area before you button it up.
To Stripped screws...
