interior light problem
Old Jun 26, 2010 | 10:15 AM
nutsy's Avatar
nutsy
Default interior light problem
int. light in my 72 wont go off. sometimes when driving it will go on and off by itself. 2 by floor and 1 in back all do this. any idea what could be cause?
Old Jun 26, 2010 | 10:34 AM
...Roger...'s Avatar
...Roger...
Probably just a door switch. Hold both switches in and see if they go off.
Old Jun 26, 2010 | 10:41 AM
nutsy's Avatar
nutsy
.tried that but it still stays on.
Old Jun 26, 2010 | 11:18 AM
...Roger...
The interior bulbs have power to them 24-7 on the orange wire. The white wire is the ground wire that turns them on and off and the wire that grounds at the door jamb switches- so the white wire is grounding somewhere. The white wire goes to every int light bulb so it could be grounding anywhere along the white wire. Do you have a bulb in between the T tops ? I have found on occasion the white wire contact rubbing the T frame and grounding. The white wire also goes to the HL switch. This circuit can be a PITA to diagnose. First thing I would do is very carefully remove both door jamb switches and see if they shut off.
Old Jun 26, 2010 | 11:45 AM
nutsy's Avatar
nutsy
thanks ROGER. i just found problem. its in the switch in the jamb as you said. the button in the door jamb is screwed into a plastic nut that also holds wire. its stripped and loose . awhen it moves its causing lights to on and off. any idea where to get this part? there is a junkyard near me. i wonder if its the same on all old chevys.
Old Jun 26, 2010 | 12:54 PM
nutsy's Avatar
nutsy
Found part and ordered. Thanks ROGER.
To interior light problem
