Tach just stop working
Old Jun 27, 2010 | 11:40 PM
den(thevetteman)78's Avatar
den(thevetteman)78
Default Tach just stop working
My tach just stop working on my '78. What should i look first ? It stuck at 2000 rpm and don't move a bit.
Old Jun 27, 2010 | 11:47 PM
Kadorja's Avatar
Kadorja
On my 80 the tach gets the RPM from the distrubitor via a small connector on the distributor. If you open the hood the part it connects to should be pointing towards the drivers side. I believe its the connector on the far right side. The one on the left is the power to the distributor.
Old Jun 28, 2010 | 07:02 AM
den(thevetteman)78
It was working fine until i shut the engine and when i started again i had to rpm reading. I disconected the RPM connector on the timmer just to make sure it was not loose and everything seems OK. Is there a way to check the tach to see if it work?
Old Jun 28, 2010 | 08:26 AM
...Roger...'s Avatar
...Roger...
Try plugging your tach wire in direct to the distributor bypassing the radio cap or tach filter first but it sounds like you have lost power or ground to the tach. Have you checked fuses ?
Old Jun 30, 2010 | 06:26 PM
den(thevetteman)78
I didn't try anything yet but i will folllow your lead.
Old May 27, 2017 | 04:47 PM
BobM1980RedCorvette's Avatar
BobM1980RedCorvette
Default tach stuck at 2000
So which fuse would it be that would affect the tach's ground and cause it to 'stick' at 2000 rpm?
I have an '80 C3 Coupe. 88,000 miles. Tach was working fine when I bought the car used in Jan. and only driven it about 100 miles since.
Old May 31, 2017 | 06:30 PM
BobM1980RedCorvette
Which fuse? Is there one for 'gauges', or is the tach connected to some other fused series of items?
Old May 31, 2017 | 07:02 PM
DUB's Avatar
DUB
Yes...you have a gauges fuse and the tach can go out and fail at any given moment....kinda like the light bulb in your lamp on your coffee table.
You tach has a pwoer wire...a ground wire and a signal wire from the distributor.
DUB
Old May 31, 2017 | 10:38 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The first thing I would do is by-pass the filter and see if the issue is still there. If it goes away replace the filter.
If the issue is still there, then I'd remove the tach from the car and test the clips in the instrument housing. Test the positive clip using a ground other than the ground clip.. then test the ground using a different power source... this will eliminate a false positive.
This PDF file will walk you through it.... If you get to the end and the tach still is not working, then replace the board.
http://repairs.willcoxcorvette.com/w...-1978-1982.pdf
If you want to send your tach into us, we can test it too.. that's not an issue... and it will eliminate a bunch of testing for you. https://willcoxcorvette.com/corvette...-service-75-82
Willcox
Old Aug 25, 2017 | 11:53 AM
BobM1980RedCorvette
Default Odd Happening / resolution of issue with Tach
So the other day I was vacuuming the drivers side of the car/floor, and noticed a fuse tucked under the edge of the floor mat. Checking charts on the fuse locations and uses, (there are conflicting versions for the '80 Corvette, I might add), I noticed the fused for "gauges" was missing (20 amp). I replaced it and the several gauges that were not working, INCLUDING the tach, worked again.
Now it's just a matter of getting the engine coolant temp gauge working, and no, the 'ground out' the connection wire doesn't seem to affect the gauge that's stuck at about 110 degrees. NOT helpful.
I may have a local garage that works on vintage cars check/do diagnosis and give me a quote. I am not a mechanic, do not have many tools nor a lift, etc.
But the TACH issus is solved. I am not sure how the fuse popped out of its own accord.
Old Aug 27, 2017 | 08:16 AM
Heus's Avatar
Heus
Im suddenly having problems with my tach not working as well. Even after installing a new tach board from Willcox it stays stuck at 5500 rpm. I verified power, ground, and tested the continuity of the signal wire as per Willcox's instructions and all are fine. It does not have a tach filter. If the instrument fuse was bad none of my gauges would work correct?
Old Aug 27, 2017 | 09:25 AM
BobM1980RedCorvette
Default Gauge Fuses / Tach
In my case what stopped working with fuse out were the Fuel Gauge, Tach, and I believe, Ammeter. The clock I believe still worked. The engine coolant temp is still NOT working and I'll have to get that checked (in my case, by a mechanic), as its problem is evently not fuse-related.
To Tach just stop working
