Question
Old Jul 6, 2010 | 08:20 AM
daxmann's Avatar
daxmann
Default Question
I have been looking at some C3's 70 and 71 only and noticed some have a key lock at the back above the CORVETTE letters and some don't. Are they both correct? If so, what is the lock for?
Old Jul 6, 2010 | 08:34 AM
Phil Zell's Avatar
Phil Zell
alarm system ?
Old Jul 6, 2010 | 08:46 AM
JW3101's Avatar
JW3101
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
Phil Zell is correct - the key lock is for the optional alarm system. I think at some point on the C3's they moved the key way to the fender.
Old Jul 6, 2010 | 09:08 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
UA6 alarm was optional 68-71. It became standard on the 72 models. Switch moved to the fender on the 74s.
Old Jul 6, 2010 | 09:13 AM
daxmann's Avatar
daxmann
Default Question
Thanks guys. What will happen if I turn the key?
Old Jul 6, 2010 | 09:26 AM
bradc6's Avatar
bradc6
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
National Champs Gators 4 St. Jude '09
Yep, it's the alarm. Mine isn't hooked up but turning the key should set the alarm.
Old Jul 6, 2010 | 09:50 AM
joewill's Avatar
joewill
probably nothing will happen, its 40 years old, your horn, harness, switches, etc.. need to be in pretty good shape.. but the theory is that if you open a door, or the hood with the alarm engaged then the horn just behind your left rear wheelwell will go off.. also it might be linked to your ignition switch.. would have to study the wiring diagram to know....
Old Jul 6, 2010 | 10:11 AM
sfallison's Avatar
sfallison
If it doesn't work.. then just tell everyone it unlocks the trunk - Then see them try to figure out how the trunk opens!
Old Jul 6, 2010 | 10:16 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by joewill
...probably nothing will happen, its 40 years old,...but the theory is that if you open a door, or the hood with the alarm engaged then the horn just behind your left rear wheelwell will go off...
The alarm must be armed (on), then a door or the hood has to be opened.
Old Jul 6, 2010 | 11:05 AM
garage-ghost's Avatar
garage-ghost
If it doesn't work... I popped mine out of the car first, then sprayed a little contact cleaner into the lock and work it back and forth...worked for me.
To Question
