Help with Year
Old Jul 12, 2010 | 09:50 PM
CobaltOwner's Avatar
CobaltOwner
St. Jude Donor '10
Default Help with Year
So I am looking to buy this car, and the guy is saying it is a '79 but it just has '81 bumpers on it, however I have this picture of the interior and it looks to be an '81 to me but I was hoping you guys could help me out since you are much more experienced then me. Thanks!
Old Jul 12, 2010 | 10:15 PM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
something smells fishy RUN FORREST RUN
Old Jul 12, 2010 | 10:19 PM
CTVETTE78's Avatar
CTVETTE78
The VIN will tell you the year.
Old Jul 12, 2010 | 11:28 PM
gbvette62's Avatar
gbvette62
The headlight **** and center gauge cluster, with the oil temp gauge in place of a clock are 81-82 items. The rear defroster switch is the 80-82 type (1980 2nd design found in 80s built after January 1980). Though the 85 mph speedometer was found in some very late production 79s (cars built in Aug 79), it is more commonly found in 80-82s. The emblem in the horn button is an 80-81 design and the hvac control with the fan symbol (instead of lines to indicate fan speed) was only used in 81-82. From the picture it's a little hard to tell the color of the interior, but if it is cinnabar (sort of a rust color), then it's an 81 interior.
Check the VIN number on the left windshield pillar. 79s have 13 digits, 81s have 17.
With 80-82 bumpers and all the 80-82 interior pieces, something is very wrong with this car if it has a 79 title. This may be one of those Corvettes that it's best to walk away from, if not run!
Old Jul 12, 2010 | 11:45 PM
CobaltOwner
St. Jude Donor '10
Thanks for all the help! I knew I came to the right place
Old Jul 13, 2010 | 09:07 AM
toolman1981's Avatar
toolman1981
That interior color is Cinabar, and as far as I know, was only offered in 1981.
Old Jul 13, 2010 | 12:03 PM
7T1vette's Avatar
7T1vette
If the VIN is a '79 number, you should be very suspicious that this is a stolen '81 car with a grafted '79 VIN. Unless there is some solid documentation of how the car came to be that way, take a pass on it.
Old Jul 13, 2010 | 04:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the VIN tag on the driver's windshield post. If the vehicle certification sticker is still on the driver's door, it has a VIN on it.
Any exterior pics of this car?
Have you checked the stampings on the pad on the block at the front of the right head?
Does the seller have any of the original documentation for this car? Invoice? Window sticker? Corvette order copy?
Old Jul 13, 2010 | 04:26 PM
Burnt71's Avatar
Burnt71
Big difference underneath , alum. rear carrier ? 79 last year before the change. Very big difference.
Old Jul 13, 2010 | 04:55 PM
vettebuyer6369's Avatar
vettebuyer6369
That steering wheel is not even a stock Corvette.
As everyone says, big differences in '79/'81. A peek at the frame, or even the hood, entire nose, etc should tell you a lot. If the VIN is '79 and the parts are all '81, then a car that should be cheap anyway becomes pretty worthless in a hurry.
Old Jul 13, 2010 | 05:28 PM
larryg3's Avatar
larryg3
i had not even thought of that but you are right. also '81 first year of the mono spring for automatic cars.
To Help with Year
