2 questions.............
Old Jul 18, 2010 | 05:28 PM
Richard Cooper's Avatar
Richard Cooper
Default 2 questions.............
The carburator on my 1981 has a nipple at the top of the carb in the back( facing window) I am sure it"s for vacuum. Does anyone know where it gets hooked to? Also, I am starting it for the first time with new crate motor is 2 gallons of gas enough to get it started?
Old Jul 18, 2010 | 05:46 PM
'75's Avatar
'75
I believe the nipple in question is for the hot air choke to draw filtered air. If you aren't using the hot air choke, you can plug it so unfiltered air doesn't get sucked into the carb.
Old Jul 18, 2010 | 08:44 PM
aussiejohn's Avatar
aussiejohn
No, no, no!
Two gallons will barely fill the fuel bowl in the carburettor! It IS a Corvette, don't forget!!!
Regards from Down Under
aussiejohn
Old Jul 18, 2010 | 08:54 PM
Richard Cooper
Guys,
Thanks a million. I'll plug the nipple and get more gas. Thanks again. Have a great week.
Old Jul 18, 2010 | 09:36 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...Richard, I would strongly suggest "priming" the engine oil system first if you haven't already. Probably the absolute most important thing you could do before starting an engine for the first time.
Old Jul 18, 2010 | 10:03 PM
Richard Cooper
Paul,
Hello there and how are you doing? Yes, I used the old distributor to prime the motor a few times.
Old Jul 18, 2010 | 10:09 PM
Skip Burney's Avatar
Skip Burney
Originally Posted by richard cooper
paul,
hello there and how are you doing? Yes, i used the old distributor to prime the motor a few times.
always always prime a new engine
Old Jul 18, 2010 | 10:14 PM
Paul Borowski
Paul,
....Richard, doing great, thinned down my herd a little. Sold the Silver '75 coupe & the Silver '68 coupe. Don't have time for everything.
...took the Orange '74 out of 18mos storage and have already put 600mi on her this year alone. Been driving the Blue '68 convertible a bit too.
To 2 questions.............
