1973 Trim Tag/Data Plate question
Old Jul 19, 2010 | 12:18 PM
Al Mc's Avatar
Al Mc
Default 1973 Trim Tag/Data Plate question
I am looking at buying a 1973. However, the Trim Tag is missing from the door jam. It is an original motor car. Lookis to be original color and trim. Is there any way to get a replacement trim tag for the car? Or is the missing trim tag no big deal?
thanks Al
Old Jul 19, 2010 | 12:26 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Is there a story as to why the origiinal tag is gone? Repaint? Color change?
If you do not intend to have the car judged and do not mind the missing tag, no harm done.
Without the original tag, it could be difficult to determine the original color combination.
Old Jul 19, 2010 | 12:32 PM
GREGG-73's Avatar
GREGG-73
Stay in tune....
Old Jul 19, 2010 | 12:34 PM
garage-ghost's Avatar
garage-ghost
Missing trim tag could be a sign of wreck repair. Look closely.
Old Jul 19, 2010 | 12:49 PM
Al Mc's Avatar
Al Mc
Default Trim Tag
thanks......any suggestions on what, where and how to determine possible repaint/damage
thanks Al
Old Jul 19, 2010 | 12:54 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Al Mc
thanks......any suggestions on what, where and how to determine possible repaint/damage...
Have you talked to the owner? He/she may have the original tag or know the story about why the tag is missing.
Old Jul 19, 2010 | 01:34 PM
Al Mc's Avatar
Al Mc
Default trim tag
talked to current owner. wasn't there when he bought it. doesn't know original owner
Old Jul 19, 2010 | 05:58 PM
7T1vette's Avatar
7T1vette
Well, that is some cause for concern. Justification for being a little more curious and checking it out well. Also make sure there are no title 'issues'. You can always get another trim tag made with the data you want on it. That isn't a 'legal' issue to be concerned with. Just Google "trim tag 1972 Corvette" and see what comes up. There have to be vendors who replace those items.
Old Jul 19, 2010 | 06:27 PM
joewill's Avatar
joewill
it is no big deal except for resaleability, which is exactly what you are concerned with regarding the current owner. and the same thing you will have to hassle with finding a buyer for it later down the road..
negotiate down to mitigate this risk..
to answer your question:
http://trimtags.com/
Old Jul 20, 2010 | 05:50 PM
Alan 71's Avatar
Alan 71
Hi Al,
The more 'original' the car is the more important the trim tag is.
For 'modified' cars the trim tag doesn't mean a thing.... unless a new owner wants to go back to 'original', then the trim tag becomes critical again.
Regards,
Alan
Old Jul 20, 2010 | 07:24 PM
Al Mc's Avatar
Al Mc
Default Trim Tag
thanks for everyone"s help and advice. The vin and proper suffix are stamped on the pad on the block. the proper code is on the trans. It is an aftermarket intake and carb with headers. It needs a front bumper, windshield and interior put back together. all there. paint is "not good" but presentable. I can buy it for 5500. any thoughts please?????
thanks Al
Old Jul 20, 2010 | 07:32 PM
GREGG-73's Avatar
GREGG-73
thanks Al
Without photos...its a tough call from where I sit...but not out of the question for the monies per your description!
Stay in tune...
Old Jul 21, 2010 | 11:40 AM
Easy Mike's Avatar
Easy Mike
...I can buy it for 5500. any thoughts please?????...
Go back and take a better look at it...Take your check book when you go.
Old Jul 21, 2010 | 12:55 PM
GD70's Avatar
GD70
If you can remove one of the rear side interior 1/4 panel trim pieces, you should see paint color there. If different from the exterior, then you'll know the original color. Takes 5 minutes to remove. Or remove a sill and lift the carpet a bit.
Can you post some pics?
See if you can track backwards from owner to owner and find out what happened to the trim tag.
Glenn
FYI-Paragon makes trim tags.
Old Jul 21, 2010 | 03:16 PM
Al Mc's Avatar
Al Mc
Default trim tag
guy has come down from 7500. lots of work done to it already. motor rebuilt, trans worked, front suspension done, lots and lots of new interior parts. I am going from pictures and will go Tuesday to hopefully pick it up. Only two missing items, windshield and front bumper cover (damaged pulling it onto a trailer).
I'll try and post some pics. If I do get it, I will probably be looking for lots of help putting it back together :-). Dash panel (gauges) has been removed and wires all over the place. supposedly all still connected, just needs put back together.
Old Jul 21, 2010 | 03:47 PM
Easy Mike's Avatar
Easy Mike
Good luck.
Old Jul 21, 2010 | 04:35 PM
Al Mc's Avatar
Al Mc
Default trim tag
Good Luck meaning I'm in for a big problem......or Good Luck it'll be easy and we know you can handle it? :-)
Old Jul 22, 2010 | 10:30 AM
Easy Mike's Avatar
Easy Mike
Good luck meaning I hope the car is what you want and no hassles on the deal.
To 1973 Trim Tag/Data Plate question
