Valve cover breather help
Old Jul 19, 2010 | 03:27 PM
Carlos840's Avatar
Carlos840
Default Valve cover breather help
Hey,
Im just looking for a breather for my valve cover, i dont have the car around to measure the size of the hole and i would like to be able to order the part before i get to be around the car again...
Here is a pic of my valve covers, they are standard GM covers.
I think the hole is 1-1/4" but id like to make sure.
Thanks a lot.
Also, do i need to take the cover off to take the tube out? Is it screwed from inside or can i just pull it out and push the breather in?
Old Jul 19, 2010 | 04:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Your valve covers look like Chevrolet LT-1/L-82. They do not have factory breathers. PCV in the left; air cleaner base connection in the right.
Old Jul 19, 2010 | 04:25 PM
Carlos840's Avatar
Carlos840
Hey, i do know that, the problem is that since i dont have a stock air cleaner the air cleaner base connection is now not connected to anything.
I am just afraid its going to suck in some crap in the engine and id rather swap it for a push on breather!
I am going to keep the PCV as it is though.
Dont know if its actually bad to not have a filter on there, but i guess its there for a reason!
Old Jul 19, 2010 | 05:51 PM
7T1vette's Avatar
7T1vette
The hose that goes into your air cleaner will serve as the "breather". If you get any blow-by out of that hose, it will show up as oil stains on the air filter by that hose. Putting another breather into those LT-1 covers would be a waste of time and money.
Old Jul 19, 2010 | 05:54 PM
Carlos840's Avatar
Carlos840
I know that, im not trying to add another breather!
I am just worried that the hose without a filter ( its NOT going into the air cleaner, and cannot go into the air cleaner) will let unfiltered air into the engine and cause problems...
I just want to swap the hose for a breather with a filter!
Is it worth doing or is the fact that i dont have a filter on this hose not a problem?
Old Jul 19, 2010 | 09:52 PM
7T1vette's Avatar
7T1vette
That unfiltered air is not going into the intake manifold and valves...it's only going into the interior of the engine. Unless you are in a sandstorm, that shouldn't be a risk. The original setup had the hose going into the air cleaner housing...but it wasn't filtered either. If you feel better about it having a breather, knock yourself out.
Old Jul 20, 2010 | 06:57 AM
Carlos840's Avatar
Carlos840
I didnt know that, i thought it was going into the engine the same way the air going through the filter was!
Well, i guess ill just leave it as it is then.
Old Jul 20, 2010 | 07:38 AM
Paul L's Avatar
Paul L
Just pull the tube out and push in one of these (or similar brands).
http://www.jegs.com/i/Mr-Gasket/720/...oductId=746269
Old Jul 20, 2010 | 08:44 AM
73StreetRace's Avatar
73StreetRace
Or those Edelbrock Elite aluminum breathers:
http://www.summitracing.com/parts/EDL-4214/?rtype=10
They even have the grommets included and they fit perfectly the stock valve covers.
Old Jul 20, 2010 | 09:10 AM
Easy Mike's Avatar
Easy Mike
Why not purchase a reproduction stock open element air cleaner? They're reasonably priced, fit correctly, and look great.
Old Jul 20, 2010 | 09:23 AM
Carlos840's Avatar
Carlos840
That is exactly what i want to do, my question was " what is the size of the hole"...
I saw loads of breathers like that but they have a lot of different sizes!
Most of them are 1-1/4" and most after market valve covers have 1-1/4" holes!
I just wanted to make sure that original GM valve covers have a 1-1/4 hole, thats it!
Old Jul 20, 2010 | 10:19 AM
Paul L's Avatar
Paul L
Two points.
That crankcase intake does have a plastic and gauze filter (in white) where the intake is outside the normal air filter (as shown). Hence the push-in type I suggested above. On my old 1967 327/300 the intake spout was inside the diameter of the air filter and had a spark arrestor but no filter (the normal filter did the job).
The hole is 1 1/4".
Old Jul 20, 2010 | 10:40 AM
Carlos840's Avatar
Carlos840
Two points.
The hole is 1 1/4".
Thanks a LOT!
Do you know if i can just pull on the hose and get it out with the grommet without taking the valve cover out, or do i have to take it off and get it by the inside?
Old Jul 20, 2010 | 10:59 AM
Paul L's Avatar
Paul L
I just pulled the steel tube out of the grommet for the pic. The grommet comes out with a little help/squeeze from a screwdriver. On the bottom side is a lip that has to be released. (Be careful not to put excess pressure on the aluminum.) But the grommet should pop out quite easily.
To Valve cover breather help
