Question about wiper door trim
Jul 27, 2010 | 11:51 AM
Hello,
I have 2 different styles of wiper door trim and was wondering which one is correct for 1969
One has holes for a screw on the edges and the other does not. The door does have the holes, so I think I know the answer, but wanted to check with the experts anyway
Jul 27, 2010 | 12:33 PM
Cruise-In II Veteran
My advice would be to check the '69 assembly instruction manual (AIM) and see what it lists. Check for a possible running change in the trim.
Jul 27, 2010 | 01:04 PM
The one without a hole is a 68, the other one is 69-72. I think a rivet was used in each though, not a screw.
Jul 27, 2010 | 01:12 PM
My 69 door has the hole on the end with trim to match.
Jul 27, 2010 | 01:20 PM
Quote:
Originally Posted by
gbvette62
Jul 27, 2010 | 02:15 PM
Definitely a rivet.
I took mine apart a few months ago.
Ordered new rivets from Corvette Central.
Jul 27, 2010 | 02:25 PM
Thanks, that's what I thought. I bought a bunch of parts from a 68 and the wiper door was one of them, but it's been a while since, and now i'm at that point to paint and install it.
Good to know on the rivets, i thought it was a screw, now I know
Jul 27, 2010 | 02:39 PM
gbvette62
I tend to agree. I'm thinking my '68 does not have the holes. Was wondering whether these may have been continued into early '69 production.
Jul 27, 2010 | 04:51 PM
The trim piece with no holes for a fastener is for a 68. The one with holes is 69 and up.
If you look at the wiper doors for a 68 and a 69, this will be apparent. The 69 is drilled for the rivet, plus it has a little more "meat" in the door casting were the hole is drilled. I'm currently using a 68 door on my 70 with a 70 trim piece. I just left out the rivet. There's no really enough metal in the 68 door to accomodate a drilled hole to accomodate the rivet.
My 68 has both the 68 door and 68 trim piece.
Jul 27, 2010 | 05:04 PM
Hi,
I believe that when the hole first appeared a 'drive' rivit was used and then in 71 (?) a tiny flat headed screw appeared.
Regards,
Alan
Jul 27, 2010 | 05:39 PM
Alan 71
Hi,
Regards,
Alan
My original '72 still has the screws ... VERY small screws not rivits.
Jul 27, 2010 | 10:52 PM
May very well have changed in 71. Mine is a 70...
Jul 27, 2010 | 11:03 PM
My '71 (12/70 build) has a small Phillips-drive flat-head sheet metal screw at each end.
Jul 27, 2010 | 11:11 PM
7T1vette
my 72 has the same
Hammadown
