Rear cmpartment doors
Old Aug 22, 2010 | 04:22 AM
C3smallblock's Avatar
C3smallblock
Default Rear cmpartment doors
I purchased some rear compartment door frames from Willcox a few months ago. I just went to install them, I removed the old broken frames from my doors but the new frames dont fit!!! They are just a tiny bit too small. My doors are orig 76 frbreglass doors, so what has gone wrong? I dont know what to do now, advice please!!!
Old Aug 22, 2010 | 07:49 AM
7T1vette's Avatar
7T1vette
I assume the prior frames were not in good shape...maybe broken (since you are replacing them). Could it be that the [pressed-board] doors have swelled some, since the frames couldn't retain them properly? If so, you can use a palm sander to smooth down the edges of the doors to get them straight/smooth and the correct size when you get them stripped. Also, when you try to assemble the frames to the door (if you are installing new carpet, too), you may want to put a piece of wood across the top of the door and use some squeeze-clamps to compress the frame and carpet together so that you don't overstress the frame and break it. When clamped down, you can put the retaining screws in place...then release the clamps. You may need to shave a bit of carpet pile off under the frame, if particularly difficult.
Old Aug 22, 2010 | 12:05 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The wood will sometimes swell and trimming the board down can usually take care of this.
Willcox
Old Aug 22, 2010 | 12:57 PM
Alan 71's Avatar
Alan 71
Hi,
I think c3 is asking about his "fiberglass" doors.
Did doors change from fiberboard/chip board to plastic/fiberglass at some time? Or are the plastic doors a service replacement or aftermarket part?
Regards,
Alan
Old Aug 22, 2010 | 01:15 PM
7T1vette's Avatar
7T1vette
Hmmm...
Good question, Alan.
Old Aug 22, 2010 | 01:37 PM
Artsvette73's Avatar
Artsvette73
Same deal with fiberglass doors/ thermo plastic. Sand them down to fit
Old Aug 22, 2010 | 01:38 PM
mds3013's Avatar
mds3013
The original doors on my '77 appear to be fiberglass. mike...
Old Aug 22, 2010 | 04:21 PM
C3smallblock
Yes Alan is correct, these are a moulded fibreglass door not fibreboard. There is too much to sand down, they are a good couple of millimeters too big.
Old Aug 22, 2010 | 05:29 PM
7T1vette's Avatar
7T1vette
If you ordered frames for your year car, you may have been sent frames for earlier year's parts.
Old Aug 22, 2010 | 08:47 PM
Wuttin's Avatar
Wuttin
Push too hard on the new frames and they will split...sand/hone/file/trim/cut the doors, or practice your expletives before you start because they will come in handy soon afterwards.
Steve
Old Aug 22, 2010 | 10:55 PM
C3smallblock
Well, I have completed the compartment doors. Rather than mangle the fibreglass ones I decided to put my woodworking skills to the test and I have made some new ones. And I am please to say that they look pretty sweet too
One question though. Where do you buy the rivets to hold the hinges to the master frame, and how do you apply them? I have tried all manor of bits and bobs that I have in my garage like nuts anbd bolts, pop rivets, split rivets and nothing worked. I am out of ideas.
Old Aug 23, 2010 | 09:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I had to trim the carpet edges on the doors to get my frames to fit. Tight, but it worked.
Early doors were fiberboard; later doors were fiberglass/plastic.
Old Aug 23, 2010 | 11:57 AM
75+78 Corvettes's Avatar
75+78 Corvettes
if you have the carpet on already, use a set of hairclippers (or beard trimmers) to chamfer the carpet on the edge (remove it at about a 45* angle). this removes the extra carpet nap that gets bunched up under the frame causing a misfitment. I did it and the frame went on snug after that. The screw kit I got had little screws that went into the frame to hold it to the fiberglass panel to hold it tight and keep it from popping off.
The rivets in my opinion are a joke and didn't hold anything tight. I ended up running the screws that held the hinge to the frame all the way to body and they arent going anywhere and also keep the frame from flexing which causes them to break in the first place.
To Rear cmpartment doors
