How does your Vette drive??
Old Aug 23, 2010 | 01:15 PM
noonie's Avatar
noonie
With these cars, you have to compare convertibles to convertibles and coupes to coupes. They don't drive the same even when new.
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
As the steering box on your C3 wears over the miles, you will get some play in the steering wheel. I have some in mine, even with a new rag joint, rebuilt suspension and new tires. If you look up Mike Shea's papers, he lays out a procedure for adjusting the lash on your box to take out that play, assuming you have any adjustment left. If the box is so worn that all of the adjustment has been taken up, you need your box rebuilt. In other words, play in the steering is not some special part of Corvette design, just the inevitable wear that happens from decades of use.
Old Aug 23, 2010 | 01:25 PM
toolman1981's Avatar
toolman1981
For every action there is an equal and opposite reaction.
Go with poly bushings everywhere!
They breakdown over time at a much slower rate than rubber, 1% per year as compared to up to 10% per year for rubber.
They significantly reduce the slop you will find with rubber, especially aged rubber.
I'm not saying this will fix your problem, but if you are planning to replace components anyway, poly will help.
I will add this for the purist,
If you plan on having a NCRS car go with rubber.
Old Aug 23, 2010 | 07:21 PM
iokepakai's Avatar
iokepakai
Default Borgeson Box!
My 76 was all over place until I installed a borgeson box and changed the rag joint with a u joint.Also put on a new set of 255/60/15 Firehawks and its like driving an almost new car with tight steering and great handling.Alohas
Old Aug 23, 2010 | 07:27 PM
Arcticshark's Avatar
Arcticshark
Originally Posted by mds3013
My '77 handles great but only has 40,000mi.. My current points of referance are an '07 Tahoe and '08 Silverado. For a non rack and pinion vehicle it is very nice. mike...
My 77 has very tight steering. It's surprising. Rides like a log wagon though....
Old Aug 23, 2010 | 07:32 PM
GD70's Avatar
GD70
Two different animals!
My coupe is pretty tight, tracks & stops straight, handles well on curvy roads. It's got a composite rear spring but it's hoppy compared to a modern day car. Very comfortable on a smooth highway.
Glenn
Old Aug 23, 2010 | 07:51 PM
Corey_68's Avatar
Corey_68
drives great...then again the only thing "old" is the body and some interior pieces.
Old Aug 23, 2010 | 08:18 PM
70_Shark's Avatar
70_Shark
'70 coupe- I basically replaced all suspension components. I think I put in the equivalent to a F41 suspension. I can feel every crack in the road (my wife not a fan of it). And I can do a cloverleaf exit at 60 mph-though it wants to break loose-and has. I'm losing my steering box so I do have a little play in it. It can be as tight and responsive or as comfortable as you want it. Mine drives like a go-cart. It's so much fun to take it out on those rare occasions when I'm not working on it.
Old Aug 23, 2010 | 08:58 PM
killain's Avatar
killain
Oldtimer
Originally Posted by zmanc3
Yep, I agree. Ball joint changeout would be on my long list of "stuff".
The bigest improvement I made to my 79 was the install of a 330 LB TRW rear spring. Did away with 90% of the rough banging and the constant rump - rump - rump as you went down a concrete road. Next was a rebuild of all the bushings, nothing special, just plain OEM or Moog replacement bushings. I did it over a span of about two years, with a litle better ride each time I replaced a set. I also did away with the old calipers and put in a complete set of VB&P stainless slieved calipers. That put problem brakes to bed permanently !
Old Aug 23, 2010 | 11:37 PM
Mark G's Avatar
Mark G
My vette had about an inch of free play at the wheel. I had to remove my steering column for some access under the dash and at one point I had it up on jack stands and happened to turn the rag joint by hand. I could feel a lot of roughness in the bearings by hand turning the box. I eventually removed the box and disassembled it. The top bearing was completely corroded at the outer and inner race. The bottom bushing was worn enough that I could feel play at the shaft with my hand. I completely rebuilt the box according to specs and the play has completely gone away.
I would definitely encourage you to look at your steering box. Personally, if you aren't set up with all the right tools, I'd just order a rebuilt box because when you factor in all your time (even if you DO have the tools), it's going to take as much to rebuild the one you have. ...so just buy a rebuild. I haven't installed a borgeson steering box, but it came out right about the time I re-did mine. It might be worth a hard look. No matter how tight your steering bushings and ball joints are, a loose box will still not give you the feel you are after. If you are lucky you can adjust yours.
Mark G
Old Aug 24, 2010 | 12:50 AM
7T1vette's Avatar
7T1vette
I've had a new '74 and a 5 year old '68, not to mention the [38 year old] '71 at present. There does not need to be any 'slop' in the C3 steering system; when new, it was tight and comfortable to drive. My '71 coupe {with over 200K miles} is about as tight as the 5-year old '68 was. But, this car has alway had good maintenance and has had worn parts replaced with OEM stuff. If you have looseness in the steering of your C3, you have worn and/or misadjusted components in it. I would suggest that you take it to a good...and highly recommended...alignment shop and ask them to do a full check out of the steering and front/rear suspension components. For just a few bucks, you can know exactly what components are in need of adjustment and repair.
P.S. The 'ragjoint' is not loosey-goosey by design; it merely provides the ability to absorb a bit of misalignment between the steering column shaft and the input shaft of the steering box.
Old Aug 24, 2010 | 04:34 PM
Archgator's Avatar
Archgator
It looks like the culprit may be the steering box as just about every other component has been replaced. I'll have it checked out. Thanks to all for all the great suggestions.
Old Aug 24, 2010 | 09:30 PM
  #33
RonCantrell's Avatar
RonCantrell
4th Gear
When I bought my 74 and drove it home it scared me to death. I rebuilt the front and rear suspension co,mpletely, put new SS o-ring brakes on it and then ried it. The steering was really sloppy. Put a Steeroids kit in it, now its right. Straight and narrow, no lean, a little rough due to stiff springs and sway bars, but I love it.
Old Aug 24, 2010 | 10:18 PM
  #34
FWMCB's Avatar
FWMCB
I have a 1980, and have the steering tightened a few times and it runs like a champ.
Old Aug 25, 2010 | 02:09 PM
  #35
couperdecar's Avatar
couperdecar
My steering has been slightly squirrely for the last couple years. Bought new BF Goodrich tires which solved the problem.
I've been thinking about replacing the upper A arms. Tech articles say that our vettes have about 2 deg camber and
replacing the A arms can give us 9 deg camber which is comparable to modern vehicles. I don't autoX but the advantage
would be on the highway. The car would come back to centre easier.
Old Aug 26, 2010 | 10:09 PM
  #36
hwcoop's Avatar
hwcoop
I love pinning my son to the door panel on 360degree hiway onramps
Mine tends to wander on roads with ruts in them but is great on good pavement. I have all new shocks, springs, ball joints, tie rods etc but when I rebuilt the steering box I neglected to change the shaft bushings (rookie mistake) I will rebuild it again this winter properly!
Old Aug 26, 2010 | 10:38 PM
  #37
7T1vette's Avatar
7T1vette
If the car 'wanders' on rutted roads, your toe-in [front wheels] may be set improperly. Some shops think that dead-straight (0 deg. toe-in) is the ideal setting. But, for a Corvette, about 1/16" to 1/8" toe-in will help to prevent that wandering problem on well-driven roads.
To How does your Vette drive??
Old Aug 26, 2010 | 11:28 PM
  #38
hwcoop's Avatar
hwcoop
Thanks,
I'll check that out
Old Aug 27, 2010 | 10:54 AM
  #39
66L36Coupe's Avatar
66L36Coupe
Originally Posted by Archgator
Thanks for the responses...I guess I just need to drive it more and get used to it. But 1 more question...when you guys say it's tight, is that compared to a new car or for a 40 year old car??
I drove my buddy's '68 442 'vert the other day (with bias ply tires no less...). After that experience, my '66 and '70 Corvettes seem like they're riding on rails. It's all relative. Mass-produced 50 year old automotive steering technology (or should I say pointing technology?) controlling 1.5 tons of steel and fiberglass, plus worn & deteriorated soft parts = slop. But that's part of the charm, right? Also, here's tip; you'll have a bit more fun if you practice steering with the throttle...
Old Aug 27, 2010 | 11:55 AM
  #40
79 vette head's Avatar
79 vette head
St. Jude Donor '10
Originally Posted by nomocrap
My 1979 was sloppy but after poly bushings, new control valve and new firestone indy 500 tires handles very tight. compared to a 2002 Z06 itgoes where you point it JAY
same here
