Quadrajet needs rebuild
Old Sep 12, 2010 | 12:04 PM
Obxairman's Avatar
Obxairman
Default Quadrajet needs rebuild
1980 vette been sitting .got it ready to crank and the carb needs to be rebuilt anybody good with these?
Old Sep 12, 2010 | 12:34 PM
golfradict's Avatar
golfradict
Well, I surely wouldn't attempt it myself, requires special tools that are hard to get your hands on. Not sure where you live but I know an excellent mechanic here in Baton Rouge with a passion for C3 Corvettes, the guy rebuilt mine a month ago.
Old Sep 12, 2010 | 12:40 PM
Vette-kid's Avatar
Vette-kid
If you FUBAR yours up, Ive got one for sale
...just sayin...
Old Sep 12, 2010 | 01:08 PM
gbvette62's Avatar
gbvette62
I've been using Custom Rebuilt Carbs here in NJ for years. I just had him do a Q-Jet for a customer with an 81. Phils been doing carbs for 30+ years. He can be reached at 732-356-4333, or www.customrebuiltcarbs.com.
Old Sep 12, 2010 | 01:40 PM
7T1vette's Avatar
7T1vette
If your carb has been on your car and worked successfully in the past, you just need to remove it, disassemble and clean it [well], and reinstall with new gaskets/etc. You also need to make appropriate adjustments to it [per Chevrolet Chassis Service Manual].You don't really need to modify/change anything if it has worked well in the past.
If you are reasonably 'mechanically inclined', buy a book on rebuilding Q-jets, read it over and refer to it during your rebuild effort. What you are wanting to do is not "brain surgery". Now, if you bought a 'junk' Q-jet core from eBay and wanted to turn it into a well-running, correct piece for a specific car...that IS brain surgery.
Old Sep 12, 2010 | 02:03 PM
Obxairman's Avatar
Obxairman
I recently acquired this barn find.i now have this and a c4 needless to say the wife thinks one is enough.This is gonna be a long term project this is the only thing from making the car move on it's own which will make this process much easier.hopping I can do this for a qouple hundred bucks.just shelled out cash for the c4.
Old Sep 12, 2010 | 02:11 PM
johnnygascon's Avatar
johnnygascon
who are you talking about Golfr? What part of BR do you live in? I`m in azalea lakes.
Old Sep 12, 2010 | 03:48 PM
golfradict's Avatar
golfradict
Well I listed Baton Rouge because I didn't know where Obxairman
lived. I live in Central, the mechanic shop I am referring to is Pride Auto about 15 mins. north of me, the owners name is Mark Straughter.
Old Sep 12, 2010 | 03:49 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
i can give you the number of the guy who just helped me redo my tri power carbs here in NY total restoration & i'm very satisfied...........
GHOST performance........if you want his number send me a PM
Old Sep 12, 2010 | 05:21 PM
PuddleJumper's Avatar
PuddleJumper
there needs to be book on how to rebuild Q-jets for the first timer book, someone needs to write one before the people who do know how to do it are gone or unable to do the tedious work..
Old Sep 12, 2010 | 06:23 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
First of all, as "7T1Vette" already said, this isn't rocket science. Secondly, there are/were 2-3 fairly good books on that subject that were available at one time. However, since '85-'86 was the last time GM put a carb on their cars as original equipment, I highly doubt that you're going to find any books with new information..... Do a search for "Doug Roe", as he wrote a book or two on Rochester carb rebuilding back in the 70s. There still may be some around.
Old Sep 12, 2010 | 06:46 PM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
I thought Lars had some articles posted here but I don't see them. Did he take them with him?
I was fortunate to get him to rebuild mine when he was still doing them.
Old Sep 12, 2010 | 07:20 PM
golfradict's Avatar
golfradict
The shop manual for my "81" shows the entire process for my
E4ME Quadrajet, dissassembly, cleaning, adjustments, tools required, etc. etc. would love to see an easier way to tackle the job, that's why I paid the expert.
Old Sep 12, 2010 | 07:37 PM
7T1vette's Avatar
7T1vette
Lars will send you the info you need IF you request it in an e-mail addressed to him: V8FastCars@msn.com
Old Sep 12, 2010 | 07:53 PM
PUNISHER VETTE's Avatar
PUNISHER VETTE
is Lars gone now?
I just bought Doug Roe's book and was going to attempt this rebuild during the winter so i could take my time.
I didn't know you needed special tools? Anyway I'm going to try and refresh mine myself so I guess when i'm done i'll know how hard it was...
Old Sep 12, 2010 | 07:57 PM
7T1vette's Avatar
7T1vette
No "special" tools required to work on a Q-Jet...
Old Sep 13, 2010 | 07:09 AM
leadfoot4's Avatar
leadfoot4
No, but if I recall correctly, in later carbs, the two air horn to fuel bowl screws located in the primary venturi were torx headed screws, so a torx driver is necessary.
The only real area of concern is the roll pin that the accelerator pump pivots on. It's not a great design, but it's there, so we have to live with it. In order to remove the air horn, the accelerator pump lever must be removed. This is done by gently pressing the roll pin inward, toward the ring that locates the air cleaner. Press the pin too far, however, and it jams up against this ring, and you'll play hell to get it back in place....
I had some ambition a few minutes ago, so I went down in my basement, into the archives. The book 'Rebuilding and Modifying Rochester Quadrajets' by Doug Roe and Bill Fisher was published in 1973 by H-P Books. However, they don't show a "stock number", or whatever number the publishing world calls them...
Old Sep 13, 2010 | 08:33 AM
damoroso's Avatar
damoroso
Like has been said already, if your carb was working well and is original, all you need to do is get a bucket of carb cleaner (not the spray can, and follow the directions for the cleaning) a good carb kit, and basic hand tools. You shouldn't need to do any modifications, or anything special to get it to work right.
Both Doug Roe and Cliff Ruggles have books out that are available and great resources. You can get all the parts you need from the local parts store, but my choice would be Cliff's High Performance for the parts, and if you'd like, you can send your carb to him to do the rebuild.
To Quadrajet needs rebuild
