Quick brake rebuild question
Old Sep 22, 2010 | 05:51 AM
briaineo's Avatar
briaineo
Default Quick brake rebuild question
If i purchase an O-ring rebuild kit, do i have to change the pistons?
placing an order with summit and they sell the rebuild kit without any pistons, do i need different pistons?
thanks
Eoin
Old Sep 22, 2010 | 11:03 AM
TimAT's Avatar
TimAT
YES! The groove in the piston is different. And if you install o-rings the calipers MUST be sleeved. Without the sleeves, the ID of the bore is wrong for o-rings.
Old Sep 22, 2010 | 11:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Quick Answer: Call Summit and ask.
Old Sep 22, 2010 | 11:10 AM
briaineo's Avatar
briaineo
Been on to them twice already today, second time was because they gave me the wrong info the first time?
Was looking for heat shields for their patriot side exhaust (which turns out they don't stock) and they directed me to three of their products : none of which would fit. They confirmed this the second time round.
Better to be safe than sorry while dealing with brakes!
Old Sep 22, 2010 | 11:16 AM
7T1vette's Avatar
7T1vette
With that kind of tech service (??), I would buy from someone else.
Old Sep 23, 2010 | 10:02 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
The o-ring changeover kit comes with new pistons. The new seals will not fit your old pistons. If the caliper has not been sleeved you are better off buying a rebuilt sleeved unit with o-rings in them. Let me know if you have any more questions.
Andrew
800-442-0335
Old Sep 23, 2010 | 11:29 AM
wcsinx's Avatar
wcsinx
thanks
Eoin
Nothing against Summit ... I've ordered many times from them. But they are a very large organization that does not specialize in Corvettes, so I wouldn't expect them to field any specific questions. For this stuff in particular I'd get the full o-ring kit from VB&P.
http://www.vbandp.com/C2-C3-Corvette...t-4-Wheel.html
$160 and I can tell you firsthand, the quality of this kit is top notch, and these guys know C3s.
To Quick brake rebuild question
