73 headlight question
Old Sep 29, 2010 | 02:05 PM
Al Mc's Avatar
Al Mc
Default 73 headlight question
I am working on trying to get the headlihts on my 73 to work properly. I bought a new vacuum kit to install and the instructions are pretty self explanatory. The question I have, is how do I test the headlight actuators to be sure they have vacuum, and the "holes" in the vacuum tank that the instructions refer to be sure they aren't clogged.
thanks Al
Old Sep 29, 2010 | 02:42 PM
Alan 71's Avatar
Alan 71
Hi Al,
You need a vacuum pump like a Mity-Vac in order to test the actuators.
Disconnect the large GREEN striped hose and attach the vacuum pump. If the vacuum holds, the internal diaphragm is good. If the vacuum pressure drops the internal diaphragm is leaking and the actuator needs to be rebuilt or replaced.
Disconnect the large RED striped hose and attach the vacuum pump. If the vacuum pressure holds, the internal diaphragm and rear sealing grommet are both good. If the vacuum pressure drops during this check, but was held in the GREEN striped hose check, only the rear sealing grommet is leaking and can be replaced.
Good Luck!
Regards,
Alan
Old Sep 29, 2010 | 02:43 PM
Mike Ward's Avatar
Mike Ward
Follow this guide:
http://www.corvette-101.com/vacuum.htm
Old Sep 29, 2010 | 04:26 PM
Al Mc's Avatar
Al Mc
Default headlights
Thanks!!! I am going to start on it tomorrow AM. Al
Old Sep 29, 2010 | 05:40 PM
...Roger...'s Avatar
...Roger...
This paragraph is from the above link. Anyone see a problem with the general function test ?
GENERAL FUNCTION TEST
The headlamps should be off and closed and the pull down switch should be pushed in. Pinch closed the small white hose leading to a relay valve and the headlamp doors should open. When released, the door should close. This operation usually can only be performed once without the car running. If this test fails and your headlamps still open and close while the car is running, it simply means the system is not operating at 100 percent as designed. The following tests should help you pinpoint why this test failed.
Old Oct 14, 2010 | 11:20 PM
Al Mc's Avatar
Al Mc
Default headlight question
started trying to resolve the problem based on the outstanding responses recieved. The test regarding actuators: My headlights are "stuck" in the up position. On or off by the headlight switch they stay up. How do I get the headlights to go down to perofrm the tests to determine if the head light actuators are working. Tried pushing them doen, but will not go. Don't wont to force them and break something.
Please help
Old Oct 14, 2010 | 11:37 PM
orourke's Avatar
orourke
I disconnect the vacuum lines from the actuators. I then reach up into the fresh air openings under the front of the Corvette. Feel for the support arm for the headlight assembly and pull down enough to release the overcenter lock. They'll close right up.Be careful not to grab the switch's that are mounted on the arm's,they'll break off easily.
Marty.
Old Oct 15, 2010 | 08:14 AM
...Roger...
Please help
Have you tried applying vacuum to the small hose on the relays ?
Old Oct 15, 2010 | 08:50 AM
...Roger...
Since no one answered this I will. The above sentences in red are .
If what is said in red above was to happen the diaphragm in the relay would be BAD.
I am not a fan of that sight. I have not read the entire thing because there are too many mistakes starting on the first page . The vacuum diagram is wrong and the general function test is flawed.
Does anyone know who the PUTZ was that wrote that ?
To 73 headlight question
