Carpet plug install tool
Old Nov 1, 2010 | 05:25 PM
TERRY CLARK's Avatar
TERRY CLARK
Default Carpet plug install tool
Well I guess it's time to make a carpet plug install tool.......Anybody done this? Got plenty of old screwdrivers !
Old Nov 1, 2010 | 06:02 PM
Alan 71's Avatar
Alan 71
Hi Terry,
I'm not sure just what you're thinking of making but the ones I've seen that look the best, have a flat washer welded to the shaft so the rear/flat part of the plug gets pressure on it too. Perhaps that's what you have in mind.
I find that warming up, and slicking up the point of the plug with grease, seems to help as much as the tool.
Regards,
Alan
PS: I do however have a nice supply of plugs with half of the point torn off.
Old Nov 1, 2010 | 07:50 PM
7T1vette's Avatar
7T1vette
Take an old medium sized Phillips screwdriver and grind the tip down so it is rounded off. That will do the job just fine.
Old Nov 29, 2010 | 01:32 PM
udornf4's Avatar
udornf4
wooden dowel works too!
Old Nov 29, 2010 | 02:46 PM
Alan 71's Avatar
Alan 71
Hi,
I've found that the original 40 year old plugs are still softer and more pliable than the new repros.
Also, discovered TWO lengths were used. Long plugs were used where the carpet plug needs to go through the carpet and rubberized firewall mat.
Regards,
Alan
Old Nov 29, 2010 | 06:42 PM
Duke94's Avatar
Duke94
I just started them in the hole then grabbed it with needle nose pliers from the other side and pulled them into place. All the holes on mine were accessible from the other side. No special tools required.
Gary
To Carpet plug install tool
