upper shock mount bolts 1972
Old Nov 3, 2010 | 02:54 PM
Sully1882's Avatar
Sully1882
Default upper shock mount bolts 1972
I am replacing old worn out shocks with new Bilsteins and the rear upper mount bolts are different. The right one has only about a half in of threading on it and then it's smooth, it looks original. The left is threaded the entire length of the bolt. I took the right one to Autozone and NAPA and no go on getting a replacement from them. Which is the correct one and where do I get another?
The whole reason for replacing the left one is not a question of originality but more of safety and function. It is slightly bent already and doesn't even look like it is automotive quality. D@mn you Bubba.
thanks everyone,
Sully
Old Nov 3, 2010 | 03:33 PM
SteveG75's Avatar
SteveG75
You want the ones with the smooth shank. That bolt is in shear and having threads for the entire length is not a good thing.
Most of the major vendors should be able to hook you up. I did check Zip Corvette and they have them in stock. Part# SU-620, $8.50.
Old Nov 3, 2010 | 05:25 PM
Alan 71's Avatar
Alan 71
Hi,
Note the 'thin' nuts shown in Steve's picture.
Regards,
Alan
Old Nov 3, 2010 | 07:25 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Alan-
I'll add to that comment.. the thin nut always goes on the inside, but the lock washer is on the head side of the bolt and not the nut side.
Willcox
Old Nov 4, 2010 | 09:42 AM
Sully1882's Avatar
Sully1882
thanks guys!
Old Nov 4, 2010 | 12:52 PM
7T1vette's Avatar
7T1vette
For the fully-threaded shock mount, there should be a steel sleeve that fits inside the upper shock mount rubber before the shock is assembled to it. If you don't have that sleeve, the shock will flop around on that upper mount and wear the rubber out very quickly.
To upper shock mount bolts 1972
