Engine compartment detailing question
I know they spray everything under the hood with some product, but it's not all oily and sticky like Armour All or Tire Shine. Anyone have any idea?
http://www.properautocare.com/pigspit.html
http://www.kmart.com/shc/s/p_10151_1...e=00-2229915-2
Available everywhere from Walmart to Advance Auto. I also use this on tires, not that glossy wet look, has a nice semi-sheen to it AND IT WILL NOT ROT YOUR RUBBER LIKE ARMOR-ALL!!!!!!!! Take the bottle and spray the eng comp and take a wipe and wipe the area down. Good for interiors also.....................
Just hit the engine minues electrical stuff like the alternator with degreaser and spray this on after. It makes a nice shine.
If you do not mind the slight oil, I use WD-40 a lot as well.
Regards
Roy
Though I have never used it....I know of a lot of detailers that swear by this stuff. Its called CD2 Engine Detailer, and can be purchased at any or all the stores noted above.
As it was explained to me, you still must have the engine bay relatively clean... having removed all the heavy grease, oil, and dust, etc. But not squeaky clean. Then just spray it on / over everything. It will appear very shiney at first, but disapates once the engine is run for a while.
Now, as mentioned in a few posts already, don't expect this product or any other type product to give you the results of Alan's 71 or eastltd's 73 engine bay. That takes an enormous amount of good ole fashioned elbow grease, complete dismantling / removal of the engine, and then a complete restoration of the engine bay and all its componets, to include paint.
Give the CD2 a try, and report back as to how it worked for you....maybe take a before and after photo to share here with others looking to do the same.
Stay in tune....
mike...
