rocker panel screws
Old Nov 20, 2010 | 08:06 PM
panicman's Avatar
panicman
Default rocker panel screws
What can I do about broken rocker panel screws?
[IMG][/IMG]
All of the trim screws came out, but all the rocker panel screws broke.
Old Nov 20, 2010 | 08:38 PM
mapman's Avatar
mapman
This link may help:
http://www.corvettemagazine.com/body/the-fix-is-in.html
Old Nov 20, 2010 | 09:03 PM
DustersVette's Avatar
DustersVette
I had the same problem on my 71 coupe.....simply drilled them out, then put the nuts behind and screwed them in. Look great!
Old Nov 20, 2010 | 09:13 PM
grantstigers's Avatar
grantstigers
[IMG][/IMG]
I would just drill it out and retap it. Then you don't have to bother with a nut in the back etc. You put the Original type screws back in as how the factory did it.
Make sure the first drill is small and a centered pilot hole. Then redrill it a little larger but smaller than original thread size so you have enough metal to retap the hole which is a fine thread.
Hope this helps.
Grant
Old Nov 20, 2010 | 11:05 PM
DustersVette
Sorry, I retaped the screws. Did not simply put a nut on the back!
Old Nov 21, 2010 | 12:15 AM
7T1vette's Avatar
7T1vette
Many of those screw holes are actually T-nuts that are spot welded to the backside of the rocker panel. You can drill them out or just drive them out; then epoxy another 10-24 T-nut in place and put the screws (stainless, this time) back in place. The end screws use sheet metal 'nuts' anyway.
Old Nov 21, 2010 | 01:43 AM
avner's Avatar
avner
to make it easy you can put rivet nut.
Avner
Old Nov 21, 2010 | 07:38 AM
Paul L's Avatar
Paul L
Another option is a repair kit. Check Corvette Central #343044. And yes use SS machine screws (Home Depot has them) or anti-seize compound.
Old Nov 21, 2010 | 08:22 AM
roger3's Avatar
roger3
I had sAme problem on my 71. The stock screws protrude out the other side of the nut. I was able grab the screw with vice grips and screw them out the back side. I had one that did require drilling and tapping.
Jack the car up so you can get eye level and drill in the center of the screw.
Good luck
Roger
To rocker panel screws
