HP Loss
Old Nov 26, 2010 | 12:03 PM
trainor's Avatar
trainor
Default HP Loss
After getting engine dyno done, does anyone know how much is lost at the rear wheels? Thanks
Old Nov 26, 2010 | 12:50 PM
Gordonm's Avatar
Gordonm
What transmission are you running. A turbo 400 is a pig. It robs lots of HP.
Old Nov 26, 2010 | 01:11 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I used to have a listing of what the transmissions took up on average. I remember the powerglide was the least, but ya give up a lot of gear ratios when you go that route
Old Nov 26, 2010 | 01:20 PM
trainor's Avatar
trainor
I've got a TH400 with a shift kit. Just kinda want an approximation, doesn't have to be exact numbers. Just kinda want some what of an idea about the loss.
Old Nov 26, 2010 | 01:45 PM
zwede's Avatar
zwede
With a TH400 you're looking at about 25% loss between engine dyno and rear wheel.
Old Nov 26, 2010 | 01:58 PM
Gordonm's Avatar
Gordonm
Old Nov 26, 2010 | 02:05 PM
C3 Stroker's Avatar
C3 Stroker
From personal experience; Mine dynoed 628 hp @ flywheel, and 490 hp rear wheel. That would be a 22% loss.
W/ TH400 trans and 2900 rpm converter.
To HP Loss
