Lock set installation tips needed
Old Nov 30, 2010 | 10:58 PM
7T1vette's Avatar
7T1vette
Default Lock set installation tips needed
I just bought a replacement lock set for the ignition switch and doors. The AIM has instructions for assembling the ignition switch, but nothing in regards to removal of the old one. And, of course, no instructions came with the new lock set. Anyone know the 'secret' for removal of ignition lock in a '71 coupe? Also, any advice on changing door locks will be much appreciated.
Old Dec 1, 2010 | 01:34 AM
Frogday's Avatar
Frogday
I changed all my locks about 2 years ago. Seems like I used one of the steering column rebuild how-to guides to figure out how to remove the ignition switch. I don't remember the specifics, but there is a notch that you will be sticking a small screw driver into to release the ignition switch and it will slide right out...that is after pulling the wheel and its hub.
The doors just have a slide clip that holds them tight...it is a lot easier to remove than to put back on. I remember using needle nose pliers to get it in place and then a long large flat screw driver to push the clip. It was enough of a hassle that I still haven't done the passenger side.
Old Dec 1, 2010 | 05:06 AM
GunPowder's Avatar
GunPowder
For the ignition switch/lock Check out Jim Shea's website where he shares his great knowledge with us
http://jimshea.corvettefaq.com/
There you will find detailed and pictured instructions for anything related to the steering (including how to change/troubleshoot the ignition lock).
Old Dec 1, 2010 | 07:17 AM
noonie's Avatar
noonie
Along with the papers,
The only problem may be the almost seized lock tab, here is the proper location and a lot of penetrant may be needed to depress the tab.
On the door locks, the side of a cold chisel between the lock and clip tab, then lever the chisel down, gives enough force to remove clip.
Old Dec 1, 2010 | 09:48 AM
qtlow's Avatar
qtlow
If I recall correctly, I think the ignition switch needs to be in the on or unlocked position too.
Old Dec 1, 2010 | 11:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: the AIM shows only the installation because assembly line workers were concerned only with installing the switch.
The chassis service manual shows replacement.
Old Dec 1, 2010 | 02:51 PM
7T1vette's Avatar
7T1vette
I never thought to look in the Service Manual for that. Thanks, Mike.
To Lock set installation tips needed
