VIN# On Frame
Old Dec 6, 2010 | 09:08 PM
Burnt71's Avatar
Burnt71
Default VIN# On Frame
Where can I find the vin# on the frame of my 71 ?
Old Dec 6, 2010 | 09:46 PM
72LS1Vette's Avatar
72LS1Vette
It should be in 2 places. Right around the middle of the driver seat on top of the frame and right above the top center line of the rear wheel, also on the top of the frame. You will need a mirror to find the number and if there is any significant rust at all the number may be gone. They weren't stamped very deeply into the metal.
Rick B.
Old Dec 7, 2010 | 12:46 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You can't see the stamp on the frame rail under the door with the body on.
You might be able to see the stamp on the top of the rail in front of the #4 mount, driver's side.
In either instance, it's a VIN derivitive and not a complete VIN.
Old Dec 7, 2010 | 04:24 PM
Alan 71's Avatar
Alan 71
Hi B71,
A pretty serious piece equipment was used to make that stamping. It was so powerfull that it often sank the vin in a slight valley that you can feel with your fingers, or see, even if the frame is quite rusty.
Good hunting!
Regards,
Alan
Old Dec 7, 2010 | 05:15 PM
Burnt71's Avatar
Burnt71
Thanks all . Found them but can't make out the numbers
To VIN# On Frame
