oops!
Old Dec 10, 2010 | 04:06 PM
udornf4's Avatar
udornf4
Default oops!
73 Convertible
Anyone have a photo of left side dash (after speedo/tach removal)?
I should have taken pics - didn't. Having trouble re-installing.
Specifically, the main harness routing (over or under the upper brace)?
And the Speedo cable over or under the same upper brace.
I have seen photos of coupes dash - They are different, they don't have all the extra braces (apparently)
thanks...
Old Dec 12, 2010 | 06:41 AM
udornf4's Avatar
udornf4
bump
Old Dec 12, 2010 | 08:28 AM
Duke94's Avatar
Duke94
These do you any good? 71' vert.
Gary
Old Dec 12, 2010 | 11:31 AM
7T1vette's Avatar
7T1vette
I can't imagine anyone disassembling/reassembling the driver's dash area "stuff" without having an AIM for reference.
Old Dec 13, 2010 | 05:37 AM
73StreetRace's Avatar
73StreetRace
This area is definitely not the most pleasant to work on...
Old Dec 13, 2010 | 07:38 AM
PUNISHER VETTE's Avatar
PUNISHER VETTE
Here's my 69....
It looks bad but putting it back wasn't as nearly as hard as you would think. Most of the bulbs are color coordinated with the dash so you just have to line up the right ones.
Old Dec 13, 2010 | 10:16 AM
udornf4's Avatar
udornf4
I have the AIM. It is really lacking on this detail.
EXCELLENT!!! Thanks guys - and Merry Christmas!
Old Dec 13, 2010 | 01:03 PM
7T1vette's Avatar
7T1vette
Getting 'stuff' connected properly is not the toughest problem. Routing all the wiring in a way where it can be reassembled without something getting pinched or putting something in a bind (or even getting it together at all) is the most difficult part. The AIM does show proper routing and positioning of those 'innards'.
Old Dec 14, 2010 | 09:52 AM
udornf4's Avatar
udornf4
The AIM does not show the detailed main cable routing coming from the firewall. For instance - the main harness is routed BETWEEN the two braces. (Braces are only found in convertibles). Also, it does not show speedo cable routing that goes ABOVE the two braces. This detail is in the pictures above and is not in the AIM. My .02
Old Dec 14, 2010 | 10:50 AM
7T1vette's Avatar
7T1vette
G;ad you've found what you need.
Old Dec 14, 2010 | 09:02 PM
texaswilkins's Avatar
texaswilkins
So you are saying those three little rods that go to the big center support are only on Convertibles? My 72 is a model kit that didn't come with those.
Bill
Old Dec 15, 2010 | 09:18 AM
udornf4's Avatar
udornf4
Bill
Bill,
What is a "model kit"??? Is your ;72 a convertible?
To oops!
