How to remove dash?
Old Jan 9, 2011 | 08:08 PM
EricU's Avatar
EricU
Default How to remove dash?
What is the process for removing the dash out of my 69?
I am redoing my interior with new carpets, seat covers and door panels and will be sprucing up the center column and installing new gauges. My dash has a big ol crack in it and my buddy is going to cover it in black leather.
I also need a new windshield, should I remove the old windshield and leave it out until I am done with the dash?
And if it seems simple to some of you, please note that I had a hard time getting the seats out because my tracks were stuck and my last big project the EFI conversion took me over three years!!!
Eric.
Old Jan 9, 2011 | 09:10 PM
milo30's Avatar
milo30
Pretty straight forward removal, just fits tight. The windshield out might help reinstalling it. I pulled my windshield and am waiting to replace it last. Removing the dash will be fairly simple once you disconnect everything since you don't have to worry about damaging it unless you are just putting a cap on it and reusing the old dash. I bought a new dash for mine. It had already been capped before
Old Jan 9, 2011 | 09:37 PM
BBCorv70's Avatar
BBCorv70
I've done this at least 4 times with my 70 over the last 26 years. Not a fun job... The wiring behind the driver side dash is a tight fit on the 70, think it's the same for the 69.
Here's a rough outline..
Start with removing the passenger side dash panel. Three screws on the top, two on the outside and two (or three?) and the gauge panel.
Once removed you'll have access to the brace which holds the top of the dash in place.
Remove screws which fasten the center console to the dash top and three screws which fasten the driver's side panel to the top.
To remove the dash top you'll need to remove the trim from the windshield pillars. You'll need to bow the dash top a bit to get it to clear the pillars. Bow only as much as needed...
I think you'll need to remove the nuts from the studs which fasten the center gauge panel to the console. I'm not sure which gives better access, from the sides or from under the console (remove the console top).
If you're going all the way with the dash...
For the drivers side it's easiest if you remove the steering column. If not you'll have to at least remove the bolts supporting it and let it drop a bit for clearance. Best to disconnect the rag joint.
Same screws need to be removed for the driver's side as were for the passenger. Pull the panel back and disconnect the speedometer and tach cables. A spring clip retains them on 70, not sure if 69 is the same or if 69 used threaded collars. Disconnect wiring and vacuum hoses, making note of where they went. The color code for the wiring are stamped on the back of the speedo and tach, nice if you forget to tag wires.
Old Jan 9, 2011 | 11:45 PM
EricU's Avatar
EricU
I guess I will just take it slow and hope for the best! This does not sound like fun.
Does anyone have any pics of where all these bolts are that I should be looking for?
Eric
Old Jan 10, 2011 | 06:48 AM
corvetteload's Avatar
corvetteload
Its very simple, you must pull all dash panels and the center gauges, once that's done the hard part is pulling the dash HAHAHAHAHAHAHAHAHAHAHAHA
Old Jan 10, 2011 | 11:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by EricU
...What is the process for removing the dash out of my 69?...
Purchase the assembly instruction manual (AIM). It helps. Take a look at how the dash was installed at the factory. Knowing how it went in is helpful when taking it out. The steering column mount bolts are also shown in the AIM.
I have always found it easier to start on the passenger's side and work my way left. Installation is the opposite; start on the driver's side and work your way right.
Go back to work on your seat mount bolts. Dash work is easier if the seats are out of the car.
Good luck.
Old Jan 10, 2011 | 04:42 PM
Alan 71's Avatar
Alan 71
Hi Eric,
I agree with Mike! I wouldn't touch the dash with out the 69 AIM.
It's very serious in there. Remember, you're dealing with 40 year old vinyl, hard plastic, pot metal castings, vacuum hoses and electrical wiring.
You can break something in an instant that will cost hundreds of $ to replace. (For example the center gauge bezel.)
Good Luck!
Regards,
Alan
Old Jan 10, 2011 | 05:29 PM
Paul L's Avatar
Paul L
Eric,
There may be some help here.
http://willcoxcorvette.com/instructi...ith_pics_2.pdf
Old Jan 10, 2011 | 11:48 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Paul, you beat me to it..
Old Jan 11, 2011 | 12:04 AM
EricU's Avatar
EricU
I purchased my interior from Wilcox, and they are going to recover my seats.
If (when) I buy the AIM from Wilcox, do they pull my dash???
I did get my seat bolts out, but I still can't find my drop light and I think I am going to need it along with a garage heater (it does drop down to the low 40s here!)
Eric.
Old Jan 11, 2011 | 08:47 AM
Paul L's Avatar
Paul L
That paper was very useful when I did the heater core and stereo upgrade.
And yes, Alan, I broke the center gauge bezel :o. Look carefully in this pic.
Old Dec 28, 2014 | 03:49 PM
Zeus-of-Boost's Avatar
Zeus-of-Boost
I DONT CARE IF ITS AN OLD POST. ITS STILL RELEVANT.
i just broke mine in the exact spot. im searching now to just make sure that i AM going to have to bow this dash up to remove it from around my pillars. SUCKS
Old Dec 28, 2014 | 04:59 PM
Alan 71's Avatar
Alan 71
Hi ZB,
The bezel was designed to break at that point in the event of a body or head hitting it during a crash.
The top dash pad does need to be humped up in the middle to get it out.
Be extremely careful!
Regards,
Alan
Old Dec 30, 2014 | 01:49 PM
Zeus-of-Boost
^ yep i broke mine in half when i tried to remove it. SUCKED. may put it back together and carpet it up. WHAT YALL THINK. i thinking is that it will be easier to remove if i need to at a later date
Old Dec 30, 2014 | 01:59 PM
Zeus-of-Boost
Old Dec 30, 2014 | 02:15 PM
MrJlr's Avatar
MrJlr
Ya.....it can get pretty ugly in there....take your time!
It's worth it
Old Dec 30, 2014 | 02:36 PM
Argiris70's Avatar
Argiris70
Wow.!!!!!!!!!
Perfect. what is under the hood???
To How to remove dash?
Old Dec 30, 2014 | 03:35 PM
MrJlr's Avatar
MrJlr
Originally Posted by Argiris70
Wow.!!!!!!!!!
Stroker
Old Dec 30, 2014 | 10:06 PM
Zeus-of-Boost
yaaah i brought a 3 yo thread back from the dead haha
OMG man you interior is amazing. with my saddle interior was black
Old Jun 15, 2015 | 10:20 PM
TreDawg's Avatar
TreDawg
It's worth it
Where did you get the radio bezel? I'm upgrading the radio in my 75 in a week or so. I've been searching for a decent looking bezel.
