Headlight Surround for 69 Corvette
Old Jan 11, 2011 | 03:00 PM
nikic6's Avatar
nikic6
Default Headlight Surround for 69 Corvette
The pot metal headlight surround on my 1969 corvette is broken on one side. The replacement part is made of fiberglass. Can pot metal be welded or repaired? I would like to keep the car original since I purchased the car new in 1969. I have looked in flee markets for years and have not seen a pot metal surround. The broken surround is on the left (driver) side.
Old Jan 11, 2011 | 03:12 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Good used original parts are easly found at J&D Corvette, Ebay and corvette salvage yards.
Old Jan 11, 2011 | 03:16 PM
MrJlr's Avatar
MrJlr
Epoxy....???
Old Jan 11, 2011 | 03:20 PM
nikic6's Avatar
nikic6
The pot metal bezel is very, very hard to find. I have seen them available but only as a complete headlight pop up assembly. They were only used from 1968-1972. Most of them broke like mine did.
Old Jan 11, 2011 | 03:58 PM
Alan 71's Avatar
Alan 71
Hi n6,
Since you mention originality you may want to investigate having your bezel repaired. Some of the shops that do custom plating also do pot metal repair.
Finding a used one for your car might be quite a job since the bezel changed over the model years as headlamp washers came, moved, and disappeared; so there are different variations that at first glance look the same.
I really don't agree that "most" of the bezels broke. The vast majority of 70-72 cars that I look at have both original bezels.
Regards,
Alan
Old Jan 11, 2011 | 05:51 PM
zwede's Avatar
zwede
Several original metal bezels on ebay right now:
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
Old Jan 11, 2011 | 06:53 PM
grantstigers's Avatar
grantstigers
Default headlight bezel
Take it to a welder and have it alum weld on the inside. May cost you 25.00 to 40.00 Take it home and grind the spots down with a metal die cutter shape of a spade. Grind the inside down and on the outside crack fill in with sandable metal compound. Then repaint with Zinc primer and you are done.
You can pm me if you are having mixed feelings about this process. I would not use glue or epoxy other than a straight alum weld.
Hope this helps.
Grant
Old Jan 11, 2011 | 07:02 PM
nikic6's Avatar
nikic6
Hope this helps.
Grant
Thanks, will give it a try.
The one on Ebay is $359 and appears to be in poor condition.
Old Jan 11, 2011 | 07:15 PM
MyRed69's Avatar
MyRed69
Hope this helps.
Grant
That's what i did with mine, $20.
Old Jan 13, 2011 | 04:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The bezel is pot metal. An experienced welder should be aware of the cautions of welding pot metal and should be able to repair your bezel.
Old Jan 13, 2011 | 08:17 PM
Richard454's Avatar
Richard454
WOW...I bought one on Ebay a few years ago for well under $100-I think it was around $40-50- In excellent shape....
OK- I feel a little better now-do a "completed listing" search and you'll see that a metal one went for $50... And the "rare" one for $125 didn't sell...
Keep looking!!!
To Headlight Surround for 69 Corvette
