correct front grill painting?
Old Feb 23, 2011 | 12:50 PM
StingrayLust's Avatar
StingrayLust
Default correct front grill painting?
Can someone post a close up picture of the correct painting for a front grill?
I've stripped my black off as all of as it was looking bad. I'm thinking of having it re-chromed and wanted to know how it should be painted.
Is the very front of the egg-crate chrome and the sides of the grate black? That's what it looks like to me but I'd want confirmation. I've seen pics of the egg crate painted all black, or just left all chrome. I'm looking for the correct implementation.
Old Feb 23, 2011 | 01:05 PM
gbvette62's Avatar
gbvette62
The grills aren't black, but instead they are a dark gray. The rough, frosted area of the grill is the protion that's painted. The front edge of the eggcrates are left chrome, as is the hockey stick shaped molding part of the grill. The edge of the 2 front bumperettes, that are closest to the grill, get the frosted area of them painted gray, also.
Old Feb 23, 2011 | 01:36 PM
Roco71's Avatar
Roco71
You are 100% right on.
Old Feb 23, 2011 | 01:40 PM
StingrayLust
A lot of shades of dark gray. Is there a specific color?
Old Feb 23, 2011 | 03:55 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Corvette Central
http://www.parts123.com/parts123/yb....0g~Z5Z5Z5GAZDP
Old Feb 23, 2011 | 04:04 PM
StingrayLust
that's one of the better close up pics I've seen. That's a pretty black looking dark gray. Maybe it's bad lighting.
Old Feb 23, 2011 | 04:43 PM
Alan 71's Avatar
Alan 71
Hi SL,
I found that the Zinc Phosphate paint that Eastwood sells is very close to the original. #10281Z
The bottom most row of egg crate doesn't have the chrome exposed; its all painted
In addition, if you look very carefully you'll see there is a groove in the chrome band that runs around the parking lens. Some people call it a 'racetrack'. This race track was painted semi-flat black on the top, and both sides of the 'track' until it got down to the level the last row of egg crate; then it was the same gray as the rest of the grill.
The zinc phosphate paint has some 'texture' and 'sparkle' as the original did.
The center grill had the same painted finish with no chrome showing.
Hope this helps you figure out how far you want to go
Regards,
Alan
PS: If you don't want to go to the trouble...Cast Blast is pretty close too.
Old Feb 23, 2011 | 05:39 PM
7T1vette's Avatar
7T1vette
A 'cast iron' color of paint is a very close match to the original shade of gray. Also, the center grille is not chrome plated and was all painted a satin black originally. Why it was different than the outer grille pieces, I have no idea.
Old Feb 23, 2011 | 06:06 PM
StingrayLust
Thanks for some great information!! I checked on the ZP from Eastwood and it's pretty spendy by the time I add in S&H. I'll try and find something close to the ZP at my local shops and go with Satin Black for the middle.
I should have known to search the forum as there was at least one other thread about this same thing. I'm betting almost every topic possible has been covered to some degree on these forums, it's just a matter of finding it that's tough.
Old Feb 23, 2011 | 07:26 PM
Alan 71's Avatar
Alan 71
Hi Charley,
I really believe the 3 grill sections had the same color gray on them; not black.
Regards,
Alan
Old Feb 23, 2011 | 07:35 PM
7T1vette's Avatar
7T1vette
I'll defer my thoughts to those of Alan71. He certainly has better expertise than I.
Old Feb 25, 2011 | 01:19 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Mine were gray-silver.
Old Feb 25, 2011 | 03:32 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by StingrayLust
that's one of the better close up pics I've seen...
That's why I posted the link.
...a pretty black looking dark gray...
Also true, but it's a dark gray. I've seen these painted argent silver and black. Neither is correct. You do not want to go in either of those directions.
Old Sep 4, 2020 | 04:26 AM
mad4slalom's Avatar
mad4slalom
Default Grills
look good in the dark gray, just importing a 72 coupe, havent noticed what the colour is, one query, I have noticed that many vettes have a bit of a gap or mis alignment of the front egg crate grills and the hockey stick trims , was there a cover piece to hide the gap or just adjust fit as best you can ?
Old Sep 4, 2020 | 08:40 AM
Mooser's Avatar
Mooser
Probably best to start a new thread (the answer is no, there was no cover or filler) rather than opening a really old thread again
M
Old Sep 4, 2020 | 09:25 AM
mad4slalom's Avatar
mad4slalom
To correct front grill painting?
