Identifying sidepipes
Old Feb 28, 2011 | 10:45 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Default Identifying sidepipes
Haven't seen this posted (even searched).
How does one know if 68-69 sidepipe covers are original or repops?
Are there any telltale signs?
Old Feb 28, 2011 | 11:27 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
The originals will be the worst looking with the most pits..........with very few exceptions. You may find the occasional NOS set properly stored for 40 years and they still look good.
The current reproductions are made from the original tooling so physically they should be the same, just new.
Old Feb 28, 2011 | 01:30 PM
Alan 71's Avatar
Alan 71
Hi AZ,
Since the reproduction covers and insulators are all made by Paragon they might have the little symbol they put on some of their repro parts.
Does anyone know if they're doing that?
It's usually done in such a way that it can't be seen when the part is installed.
I have a set of over-the-counter covers and pipes I bought in 1971. I'm not sure if even THEY are different than the production line parts were.
Regards,
Alan
Old Feb 28, 2011 | 01:38 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You don't have to worry about the 68 factory covers...they're aren't any.
69 only.
Old Feb 28, 2011 | 01:42 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
If they are on a 68 they are not original to the car. If they are on a 69 the serial number should be 9320 or above. They weren't offered before that. There should be no rocker panel trim tabs and no exhaust hangers at the tranny.
Old Feb 28, 2011 | 01:47 PM
vettebuyer6369's Avatar
vettebuyer6369
'69 only, of course. Look at the rear valance panel, too. Some people add sidepipes but either neglect to do the body work to fill the rear exhaust holes or they go the el cheapo route by putting a "filler" panel on there and hope no one notices.
Old Feb 28, 2011 | 11:36 PM
AzMotorhead
Thanks for the input so far guys.
I'm aware of telltale signs if a car was equipped with them or not,rear valance, spacer under trans mount instead of hanger bracket,
I'm trying to determine if I have a original set of covers or a re-popped set.
Debating on whether to deconstruct them for restoration(chroming) or not.
By Deconstructing i mean drill out pop rivets holding the inner shield and insulator together.
Old Mar 1, 2011 | 08:39 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
I know that my covers are original and they don't look so good either. I wish I could tell you what to look for but I've never studied the repros. Unfortunately mine are on the car now and I don't have any photos of the insides. They rattle and need to be restored...but I have heard that could easily cost as much, if not more than new. I just think that by the time you deconstruct them, try to repair...then end up replacing broken or rusted insulator and shield pieces, pay to have everything straightened up, smoothed out and re-chromed, then put it all back together...they will not look as good and be as tight as the repros.
To Identifying sidepipes
