Saran wrap Frame?
Old Feb 28, 2011 | 09:47 PM
bryanpl123's Avatar
bryanpl123
Default Saran wrap Frame?
I've just completed restoring my chassis and once I get my Differential back I'm looking to drop the body back on the frame and begin stripping the paint, then prep and prime... I've seen others with wrapped frames to keep them nice after all the hard work.. my concern is about how to get all the plastic off when I'm done painting... won't some get stuck under the rockers atleast and then trap moisture? Any tips/advice?
Thanks,
Bryan
Old Mar 1, 2011 | 12:05 AM
grantstigers's Avatar
grantstigers
Thanks,
Bryan
I wrapped my whole frame, gas tank, motor. I used that pallet wrap plastic. Wrap just firm and not stretchy tight. Don't wrap around any frame mounts or places where the body will sit on the plastic otherwise it will be a bitch to take off.
Rockers are not added on till the car is completely painted. By then you should have been under neath cutting and pulling the wrap off.
Hope this helps.
Grant
Old Mar 1, 2011 | 09:59 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Hope this helps.
Grant
Grant,
How's that 72 coming along anyway? Last pics I've seen were bare frame with the block installed (if I remember correctly).
Terry
Old Mar 1, 2011 | 10:32 AM
RobRace10's Avatar
RobRace10
I wrapped mine before I dropped the body and it was no problem getting it out once the car was painted, just make sure you don't wrap over the mounting points.
Old Mar 1, 2011 | 12:28 PM
bryanpl123's Avatar
bryanpl123
Rob, Thats what i was wondering... How hard/easy is it to get the wrap off once you are all done. So I guess avoiding mounts...easy
Grant...by rockers...I ment the rocker channels I wan't sure if their may be a pinch point somewhere there.
Thanks all!
Old Mar 1, 2011 | 03:04 PM
Alan 71's Avatar
Alan 71
Hi Bryan,
I wrapped very carefully and it came home from the painter's shop pretty clean.
It's worth putting extra effort in the wrapping. You have to be a little smart so you wrap it but it can still roll.
A single large sheet over it all as you drop the body to fit the doors and hood helps too.
Regards,
Alan
To Saran wrap Frame?
