73 exhaust tips
Old Mar 17, 2011 | 08:26 PM
oldsarge's Avatar
oldsarge
Originally Posted by Blue73Shark
On Ebay. Correct weld seams on the bottom. No part numbers stamped on them. They came off a 454.
If I am not mistaken, yes they did have a seam at the bottom, however I do believe they had a stamp number on originals.
GM 330977
There are some aftermarket ones that now have the seam, on the bottom, maybe that is what you got?????????
Old Mar 17, 2011 | 08:34 PM
Vetteaddiction's Avatar
Vetteaddiction
Originally Posted by SilverDevil
Same for all 3 engines. Originals do not have part #'s embossed, service replacements do.
Has anyone ever noticed in M.F. Dobbins book he has a picture of the tips on a new '73 - they have part #s on both sides.
I know this is contrary to what the judging manual says, but I find it interesting. Any ideas from original '73 owners?
Chris
Old Mar 17, 2011 | 09:26 PM
Mike Ward's Avatar
Mike Ward
There's a fair amount of pics in Dobbins books that are actually of service replacement items. The photos were not taken in 1973 when the cars were new.
Service replacement tips (like in the book) had part numbers, they are not rare.
Old Mar 17, 2011 | 11:29 PM
talltxin's Avatar
talltxin
My original 73 tips have no part numbers on them at all. I will see if I have a good picture of their postion to post so you can see them. One of my mufflers is not correct so it hangs down a bit and looks different but the tips fit the openings nicely.
parking lot is not level it's not a problem with the car
Old Mar 18, 2011 | 12:40 AM
C7GrandSport's Avatar
C7GrandSport
Correct - Many of the pictures in the Dobbins book are of cars that had original parts removed and/or replaced. These are not pictures of 1973's just after they rolled off the assembly line, so they are of limited value! As an example, look at how many of the engines are missing the smog system.
Old Mar 18, 2011 | 12:56 PM
Patrick73's Avatar
Patrick73
Photo of original 73 muffler and original exhaust tip.
Photo of 73 muffler hanger and 73 tip.
Old Mar 18, 2011 | 02:03 PM
Tom73's Avatar
Tom73
Thanks all. I have 72 tips on my car and looking to buy 73 tips.
Got a set of original 73 tips on the way. The AIM provides one measurement for installation. Can anyone provide pics of an original installation showing:
1) a shot straight on from the back (to see how they are centered)
2) a shot from the side (to see how far they stick out)
Thanks.
Since you have '72 tips on your car I am assuming that a previous owner replaced the '73 mufflers with a set of '72 mufflers since they have greater availability (and better price) then the '73 mufflers. So to use the '73 tips you will need to get a set of '73 mufflers. The outlet pipe on the muffler is aligned differently to get it to the center of the exhaust tip (where '72 was offest to the outside of the exhaust tip).
This article over on the '73 Spot has a good shot of an original '73 from the side (second pic in article). This was the Corvette News intro of the new '73. http://www.73spot.com/article_files/cn1072.pdf
Old Mar 18, 2011 | 02:20 PM
Mike Ward's Avatar
Mike Ward
Those may or may not be original tips (can't see underneath), but those are not original mufflers unless somebody went to the trouble of removing all the factory blackout. Some service replacements also had the blackout treatment AFAIK.
Old Mar 19, 2011 | 12:49 AM
Corvette Charlie's Avatar
Corvette Charlie
The 73 tips are a 2.5 inch oval specific to that year. Not the 2.0 inch offset that were offered 70-72,
Old Mar 19, 2011 | 09:45 AM
Tom73's Avatar
Tom73
Factory are 2" tubes.
