Will this work?
Old Apr 1, 2011 | 01:03 PM
EgoTrippin's Avatar
EgoTrippin
Default Will this work?
Hi fellow C3 owners,
I took my '77 corvette to the shop a few weeks back because the brake pedal was feeling spongy (I previously bled them to try and fix it, but the problem came back after a couple weeks, it is not leaking from what I can tell) and they said my brake master cylinder was going bad. (~$250 to replace I was told)
I would like to replace this myself with the help of a couple of my friends, but I need to know which Brake Master Cylinder will work well with my car.
I was thinking of this one:
http://www.amazon.com/Raybestos-MC39...ar=1&carId=002
I'm not sure how confident I am in Amazon's "make sure it fits" option so I wanted to confirm with a couple of you that this part will work well. If it doesn't and you have a better suggestion then I'm all
Thank you in advance!
Old Apr 1, 2011 | 01:14 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Why fool with Amazon? You can get a new/remanufactured master cylinder over the counter at the generic auto parts places. The Corvette aftermarket providers also carry them.
Power brakes were standard on the 77s so you will want a master cylinder for power brakes.
Old Apr 1, 2011 | 01:22 PM
EgoTrippin's Avatar
EgoTrippin
Gotcha Easy Mike, to O'reillys I will go after work.
Thank you for the quick reply!
Old Apr 1, 2011 | 02:35 PM
79L48's Avatar
79L48
I just replaced the MC on my car. The actual replacement time is significantly less than the time it took to find a suitable gasket and retainer for the back end of the MC that butts up to the vacuum booster. I ended up cutting a gasket to fit out of rubber and re-using the retainer.
Make sure to follow the instructions on bench bleeding the MC and then bleed the brakes thoroughly and you will be good to go.
Excepting the gasket issue, It took me 2 hours from start to end. Total cost? $80-ish.
Old Apr 1, 2011 | 03:04 PM
EgoTrippin's Avatar
EgoTrippin
Thank you for the additional info 79L48
Old Apr 1, 2011 | 04:03 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by EgoTrippin
...to O'reillys I will go...
Bingo. Compare your old one to the new one and ensure they're the same. O'Reilly's will probably want you old one as a core.
To Will this work?
