Starter Trouble Again......Help!
Last week, with your help, you assisted me in the process of changing the starter on my 1980 L-48. I had killed it by cranking too much (due to fouled plugs).
I replaced the unit, and everything worked great. This morning, I took her out for a spin, and came home. Later, when I went to start it.....nothing. I have a solid battery and even tried to jump it.
I let it rest a while, and tried to crank it again. Then I saw smoke from the pass side-the wires to the starter were cooking, and one broke in two!!!
Any idea why this would have happened? I had no issues before? Maybe the unit seized up, and the power fried the wire? I want to trouble shoot this, and want to know the best way to do it.
Any ideas?
Help!
1. When you installed the starter, you didn't route the wires as they were intended. As a result they rubbed on something or got overheated and touched something they shouldn't.
2. For some reason there is a huge power draw to the starter that overwhelmed your wires.
I am leaning toward #1 based on your newness to this car and you are still in the learning process.
Replace the wires, make sure they are routed out of the way, there is a clean tight ground and try it again.
BTW, I did wash the car after I parked it, before I tried to restart-could water have effected it? I was thinking this could be a possibility, but with the starters location, I would assume it would get wet all the time when it is raining....
Just change the wires and make sure it's all grounded right and give her a whirl.
Wires 1, 2, and 3 all come together at the same bolt.
Wire # 2 is the one that fried.
Wire #4 is a black wire that mounts on the 'R' (smaller) bolt.
I wired just like the old starter-is this correct?
As for the correctness of the wiring, I would have to look at a manual or at the bottom of my car to see. Right now I am dressed for church. so I'm not going near the garage.
Is the insulation on all the wires in ok shape? I still think the cause was arcing or the high energy wire on the frame or other metal.
Make sure the ground wires are on clean metal and tight.
The "S" terminal on the starter solenoid goes to the starter switch
The "R" is the coil resistor bypass (boosts the coil on start) that goes directly to the coil.
The alt (red fusible link wire) connection appears to be OK.
See if the burnt/melted insulation is limited to the immediate area of the connection only. My point is, if the insulation of that wire within the wire harness shows no signs of excessive heat, then the problem is isolated to the area around the starter - between the starter and where the damaged/melted insulation ends. (I'm guessing it is isolated to the starter area, or you would have blown a fuse before that wire would melt in two (suggesting a short occurred between the solenoid connection and the fuse(s).) See if there is somewhere where that wire came to ground for some reason; abrasion, or perhaps due to proximity with the exhaust the insulation got soft and the wire within "pushed through" to a ground point somewhere along it's length. Just a thought.
Oh! And do I dare mention that if that wire shorted to finally burn through, there is the possibility that the battery has drained significantly and might benefit from a recharge...I'm just sayin'!
Keep us informed.
P
(1) Source:"Corvette 1966-1982" by Motorbooks
Last edited by Paul Workman; Apr 3, 2011 at 09:58 AM. Reason: Oops! His is an 80, not a 68...
Perhapsyour right, and it got soft and grounded somewhere causing the melting. Question is, is the starter shot, or is this a wiring issue? Any way i can test without having to pull the starter out again?
Also, where is the best place to get a couple new, inline fuseable wires to replace #2 (and #1 while I am at it)?
As for the fusible link that opened...Something in the load on that wire is shorted. See if you can see the other end of the heat damage. That will either be the location of the short, or narrow your hunt down.
Good luck.
P.
Larger black battery cable and 2 red fuselink wires to the big battery lug on the solenoid.
Purple wire to the "s" terminal
Nothing to the "r" terminal, in fact the correct solenoid doesn't even have the "r" terminal.
A black wire should be the ground wire. To be sure check it for continuity to ground. I like to tape it back up the harness a bit and use a short bolt to mount it to the back of the head, out of sight and out of mind.
Also, I want to replace the 2 red fuselink wires. Can I buy replacements at the autoparts store? Should I ask for anything specific? Gauge, voltage, etc?
I appreciate your spirit and gumption to do your own troubleshooting, but at this point I think you're far better off having someone (maybe from the board) show you the ropes here while you look over their shoulder.
JMHO...
P.
