I would like some advice on freshening up the wheel wells on my 76. I've seen some posts that recommend black paint, some with truck bed spray on-liner. Looking for any recommendations...Thanks.
Thanks Alan and Dustup7T2. A compliment from you guys means alot. I shot it with Wal Mart Krylon Satin. The undercoating on the jack and battery wells is 3M in the pale green can that Tracdogg2 recommended. I had lost most of it due to the pinion seal leak. It matches the original very well. Undercoating in wheel wells is factory. Again all shot with the satin. It gets a bad wrap but when I painted part of the frame and went back to clean the next section my drill mounted wire brush would not remove the previous layer. Here is the same area before. mike...
