Lower radiator hose question
Old Apr 17, 2011 | 02:41 PM
BARRY L-48's Avatar
BARRY L-48
Default Lower radiator hose question
I am replacing all the hoses in my 77 coupe and cannot get the lower hose installed,any tricks to get it on,I have now cussed it in 7 languages,any help greatly appreciated!
Old Apr 17, 2011 | 02:49 PM
Phil Zell's Avatar
Phil Zell
Keep cussing, you will get it. There is no easy way to change that particular hose that I know of.
Good Luck
Old Apr 17, 2011 | 03:02 PM
myoriginal77's Avatar
myoriginal77
Be careful not to wiggle the part on the radiator that the hose attaches to, it will loosen the connection and make it leak. Ask me how I know ...
Anyhow, I usually put a little spit (gross i know, deal with it, it works) on the radiator and the inside of the hose, and a slight wiggle, it will go on after a couple tries . It's a character builder.
Hope that helps,
Frank
Old Apr 17, 2011 | 03:07 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Spread a little dish detergent on the inner surface to lubricate it.
Old Apr 17, 2011 | 04:04 PM
hwcoop's Avatar
hwcoop
Works everytime, don't forget the hose clamp. I positioned mine so I could tighten it from underneath.
Old Apr 18, 2011 | 04:12 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Ok take off the A pillars
Take off the shroud
Take out the fan blade
remove the radiator
put bottom hose + clamp on the radiator
Re-place everything you just took off.
Re-alighn the front end.
I used my girlfriends hands to get it on now the clamp well thats another Beer (case).
Old Apr 18, 2011 | 06:05 PM
7T1vette's Avatar
7T1vette
Use the dish detergent/light-wipe-of-grease approach for getting the new hose to slip onto the radiator fitting. If you can't get any leverage on it, wrap some duct tape around the hose and leave long enough tape ends to use for 'hand holds' for pulling the hose into position. Then, [carefully] slice through the tape and remove it.
Old Apr 18, 2011 | 06:47 PM
johnt365's Avatar
johnt365
Some parts stores actually sell "radiator hose grease" in little packs. I used it last time and they went on real easy and were easily repositioned several weeks later.
___________________________
I support In Home Senior Care in Austin
Old Apr 18, 2011 | 11:48 PM
BARRY L-48's Avatar
BARRY L-48
My thanks to all that replied,I finally got the job done after taking a few hours break!
To Lower radiator hose question
