Turn signal problems
Old Apr 18, 2011 | 09:50 AM
rfoster19's Avatar
rfoster19
Default Turn signal problems
Out of no where my turn signals stopped working, I use only factory replacement bulbs, I changed out the flasher and that didnt work. Any suggestions? I live in Mullica Hill, NJ if someone is nearby and can lend a hand, I will buy the beers or will barter for computer work. I dont want to drive it because I am sure I will get pulled over!
Old Apr 18, 2011 | 10:44 AM
garage-ghost's Avatar
garage-ghost
Old Apr 18, 2011 | 01:21 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you checked the fuse?
Old Apr 19, 2011 | 08:37 AM
rfoster19's Avatar
rfoster19
Fuses are good.
Old Apr 19, 2011 | 10:39 AM
7T1vette's Avatar
7T1vette
Which "flasher" module did you change? There are two on most C3 Corvettes: one for the emergency flasher and another for the turn signals.
Old Apr 19, 2011 | 03:11 PM
rfoster19's Avatar
rfoster19
Thanks, I must have had the wrong flasher, installed another and everything is working now. Dumb luck I guess!
To Turn signal problems
