1979 tach issues
Old Apr 22, 2011 | 10:25 PM
lunerknight's Avatar
lunerknight
Cruising
Default 1979 tach issues
So i just got my first project vette and i finally got it running, so this is hoe my tach works when the car is off and not working it's pegged out all the way to the right in the red line, when i turn the car over it starts to drop back to the left.. but as soon as the car starts it pins back to the red line... can any one help ???
Old Apr 22, 2011 | 10:47 PM
pauldana's Avatar
pauldana
New tach board.... Wilcox Corvette..~$50..
Just remove the speedo/tac cluster with the 4 screws, and reach around and disconnect the speedo cable and you in like flint....
79's RULE!!
Old Apr 22, 2011 | 11:37 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is a testing information sheet on how to remove the tach! Plus... if you look on there I have a link to a video on how to install the new board as well.
http://willcoxcorvette.com/repairand...lp.php?hID=290
Here is a detailed instruction sheet on how to replace the board.. (the video is better, but this will give you some assistance.
http://willcoxcorvette.com/repairand...lp.php?hID=252
Here is the tach board.. and yes.. I have to say it is bad.
http://willcoxcorvette.com/product_i...ducts_id=25990
Willcox
Old Apr 23, 2011 | 03:27 PM
1nicecorvette's Avatar
1nicecorvette
no need for removal of the speedo cable that tach just pulls out (with board) it is attached with the three "connection tabs in the rear of it" kinda plugs in
Old Apr 24, 2011 | 07:30 AM
C3 4ME's Avatar
C3 4ME
Yup, youre lucky you have the dash you do, others have to pull the whole speedo-tach cluster. On 79's, the tach comes out by itself. BTW, a new tach board fixed my problems with my 79's tach, so here's another vote for a new board.
Old Apr 25, 2011 | 04:25 PM
1nicecorvette
vote #3 same symptoms and it fixed mine too.
Old Apr 25, 2011 | 04:30 PM
0Willcox Corvette
Former Vendor
Have you all checked out the help page we did on this....
Old Apr 26, 2011 | 09:51 PM
lunerknight
Cruising
Well i ordered the new board, so while in my free time i got it all taken apart and on the back of the board there is a huge black spot. so that must be the issue, I will update when i get the new one in. thanks for all the input
Old Apr 27, 2011 | 01:04 AM
0Willcox Corvette
Former Vendor
And make sure to watch the video on how to do the zero set on the tach.. This is most important!
Willcox
Old May 1, 2011 | 02:46 PM
lunerknight
Cruising
I broke the tach needle and no one has them in stock.... that i know of, dose anyone have one they would like to sell ?
Old May 1, 2011 | 05:02 PM
0Willcox Corvette
Former Vendor
Luner..
Where at? Can you post me a picture..
If it is just the white portion since you know how to adjust the limits of the tach, you can epoxy it back and touch up the white. It will change the needle weight and you'll have to re-calibrate the tach.. but there should be plenty of room to do this.
You have to be sparing with what you use. To much weight and you can't calibrate it.
Willcox
Old May 1, 2011 | 05:27 PM
lunerknight
Cruising
Willcox's It broke in like three pieces.. and one piece is MIA. so iam lost anything i can do?
Old May 1, 2011 | 05:43 PM
0Willcox Corvette
Former Vendor
Maybe not..
You may be able to swap the spindle part out with a speedo needle. I'm checking that for someone tomorrow. Was that you who sent me the email about this today????
Willcox
Old May 1, 2011 | 08:40 PM
lunerknight
Cruising
Yep that was me
Old May 2, 2011 | 11:49 PM
0Willcox Corvette
Former Vendor
Ok.. good.. sent you another message today.. and also sent s copy to the peeps you got the needle from.. they'll make a change I'm sure.
Old May 3, 2011 | 04:51 PM
lukyn's Avatar
lukyn
Default AutoMeter Monster Tach....
with shift light stapped to the steering column angled over the in dash tach! Easy hook up to the distributor too!
Old May 3, 2011 | 08:17 PM
0Willcox Corvette
Former Vendor
I think he may be trying to preserve the originality of the car.. Not sure an autometer is what he is looking for.
To 1979 tach issues
