Drivers door sagging
Old Apr 25, 2011 | 10:47 AM
Bad Chad's Avatar
Bad Chad
Default Drivers door sagging
I bought this 1980 Corvette yesterday and the door is sagging really bad because the frame is rusted. Is there any thread that show how to fix this or is there a company that sells a replacement door frame?
I did a search and could not find anything unless I'm wording it wrong.
Old Apr 25, 2011 | 12:32 PM
BBCorv70's Avatar
BBCorv70
If the door is sagging it could be because the hinges are worn or there may be issues with the birdcage. Badly rusted door hinge pillars or rocker channels may cause a door to sag. I know there are inserts available for either situation though the repair involves a lot of labor.
The birdcage is the framework the cab of the body is built on, windshield frame, rocker channels, hinge pillars, etc.
When you say the frame is rusted, are you referring the chassis? The frame the body rests on or the birdcage, framework the body is built on?
Do you have photos you can post illustrating the problem?
Old Apr 25, 2011 | 01:28 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Post pics. New hinge pins and bushings usually fix sagging doors.
Old Apr 25, 2011 | 01:44 PM
Bad Chad's Avatar
Bad Chad
I will post some pictures when I get home but I'm thinking it is going to be the bird cage. The frame where the door hinges bolt to is moving around due to the rust, it looks real weak.
Old Apr 25, 2011 | 01:46 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Thats no good. I might have a replacment part off of my parts car I could sell you. Just let me know which peices youll be needing. Im goin to be cutting it up in a few weeks
Old Apr 25, 2011 | 02:31 PM
Bad Chad's Avatar
Bad Chad
Is there a way to fix it without disassembling the whole car? I'm not looking to restore it, I just bought it to use as a daily driver to keep the miles off my truck. I have a complete shop so doing the work is not an issue, I just don't want to get into a huge restro project.
Old Apr 25, 2011 | 09:07 PM
Bad Chad's Avatar
Bad Chad
Looks like it is a combination of door pins needing to be replaced and the Bird cage in bad shape. I can fab something up to strengthen the bird cage but I'm going to order some door pins/hinges so that the door shuts good.
Passenger
Drivers Side
Old Apr 25, 2011 | 09:18 PM
dannyman's Avatar
dannyman
Keep that camera shooting. Let's see the rest of the mounts.
Judging by the picture of the passenger #2 mount,you have serious problems.
Drivers side is difficult to see.
Old Apr 25, 2011 | 10:16 PM
champs65's Avatar
champs65
Ouch!
Chad, I wouldn't order any pins yet. Essentially, you don't have anything holding your A-pillar (and the body) to the frame. Your hinges are always going to be moving around, flexing and changing the alignment of your doors until your #2 body mounts/rocker channels are rebuilt...Not to mention your #3 body mounts that support the B-pillar and the latch assembly for the door.
Old Apr 25, 2011 | 11:07 PM
ikwhite's Avatar
ikwhite
I would take it to were ever you bought it from and get your money back. I dont think most places would allow you to sell a car in that condition except as for parts. That car in that condtion is unsafe to drive and should not be able to be sold as a daily driver least wise thats my opinion. Either way good luck, as thats no easy or cheap repair been there done that.
ikwhite
Old Apr 26, 2011 | 01:49 AM
onaqwst's Avatar
onaqwst
the doors are not the problem....check all body mounts asap.... and pillars around windshield
Old Apr 26, 2011 | 05:44 AM
champs65's Avatar
champs65
ikwhite
Good idea. Whoever had that car recently knew about this....as evidenced by the dynamat under the carpet and the expandable foam behind the kick panels covering/hiding the body mounts.
Old Apr 26, 2011 | 10:37 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by champs65
Ouch!...I wouldn't order any pins yet...
Sorry to say, you've got way much more of a problem than hinge pins and bushings.
Old Apr 26, 2011 | 10:42 AM
chstitans42
TheCorvetteBen
Yeah I wont be able to sell you a replacment birdcage, but I know someone who does. his name is tracdogg2 here on the forum. Im sure he will be willing to part with the peices you need
Old Apr 26, 2011 | 11:10 AM
Bad Chad's Avatar
Bad Chad
Well ****, this does not sound too good... I'm going to put it on the lift tonight to see what the bottom side looks like.
Old Apr 26, 2011 | 06:46 PM
dannyman's Avatar
dannyman
Be careful the lift doesn't go through the car.
Old Apr 26, 2011 | 07:09 PM
Paul L's Avatar
Paul L
Chad,
Return the car to the seller. It needs much too much work to become safe. I doubt that it can be saftied for the road. If it was one of those "as is, where is" deals you might have a problem but give it a try.
To Drivers door sagging
Old Apr 26, 2011 | 07:18 PM
chstitans42
TheCorvetteBen
Originally Posted by paul 74
Chad,
The problem with that type of rust, in order to repair it all, you pretty much have to separate everything from everything...
Old Apr 26, 2011 | 08:41 PM
Bad Chad's Avatar
Bad Chad
I paid cash from an individual so I doubt I would get anything back. I have a friend that has a Chassis shop and I will just see what he can do with it. If he can built a 25.5 chassis I sure he can handle this.
Old Apr 26, 2011 | 09:45 PM
dannyman's Avatar
dannyman
I'm hanging around on this one. Let's see follow-up pictures! Keep us posted.
